Possibly getting cams. - Mustang Evolution
Old 10-27-2013, 08:37 PM   #1
Mustang 4pt0's Avatar
I'm thinking about buying some cams. Any idea where I could find some at? AM doesn't have any for us sixxers.
Mustang 4pt0 is offline   Reply With Quote
Old 10-27-2013, 09:01 PM   #2
Supersixmotorsports is the only place I know of that does cams for the 4.0, and they are expensive.
Old 10-28-2013, 10:09 AM   #3
08Mustang's Avatar
Tom morana racing as well...you could always get comp cams to do a custom shaft but that'd be the priciest option probably
08Mustang is offline   Reply With Quote
Old 11-02-2013, 12:37 AM   #4
davidcseifert's Avatar
Region: Arkansas
I can most likely get you a set of cams, just need to find cores to regrind
blower/new cam soon
Old 11-04-2013, 06:11 PM   #5
Chadtyge's Avatar
What's the best way to instal them? Try to do them your self or have it professionally installed? Just curious because I plan on doing cams as well
Chadtyge is offline   Reply With Quote
Old 11-05-2013, 11:17 AM   #6
JimC's Avatar
Cams are not easy to install on the 4.0. The timing chain on the passenger side is on the back. Then you also have to degree the cams properly. If you haven't worked on the 4.0 before it is not a DIY
JimC is offline   Reply With Quote
11:35 AM
