Electric help - Mustang Evolution
Old 10-28-2013, 11:20 PM   #1
Sparkz's Avatar
Electric help
I've got my mind set on putting some LEDs in the footwell of my car, it's a 2009 v6 45th anniversary. I'm thinking I should draw power from the dome lights but not sure where to splice the wires to give the LEDs power, help?
Sparkz is offline   Reply With Quote
Old 10-29-2013, 12:03 AM   #2
Tyoung68's Avatar
All you gotta do is find the dome light power wire splice in you power wire and then run a wire from a ground on your leds to a body ground
Old 10-29-2013, 07:23 AM   #3
Sparkz's Avatar
You wouldn't happen to know the color of the power wires for the dome lights would you?
Old 10-29-2013, 11:28 AM   #4
Tyoung68's Avatar
No i dont but im sure you can find it on google
Old 10-29-2013, 11:44 AM   #5
qccoles's Avatar
Do you have an aftermarket headunit? I have red LED's in my footwells that are on whenever the radio is on.
qccoles is offline   Reply With Quote
Old 10-29-2013, 01:10 PM   #6
The wires to the dome light are in the passenger side pillar. Something else you could do is in the passenger side foot well open the fuse panel box and use a test light to find a fuse that's on while the key is on and off with the key off. Just ground the negative. There's a bolt grounded under that plastic interior piece and wrap the power wire around one side of the fuse's spades and plug it back in.
Old 10-29-2013, 01:26 PM   #7
Mlarv5's Avatar
I agree to the point you say wrap the wire around the spade lug and plug it back in. I have seen to many problems with doing that on the smaller fuses. I would recommend one of these. Cooper Bussmann/ATM fuse tap (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
These are a lot safer I feel
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 10-29-2013, 01:28 PM   #8
Sparkz's Avatar
I thought about drawing the energy from the fuse box at first, but I just had no idea what to do when I opened it up
---------- Post added at 01:28 PM ---------- Previous post was at 01:27 PM ----------
what'd you wire it to for the radio?
Old 10-29-2013, 01:34 PM   #9
Originally Posted by Mlarv5 View Post
I agree to the point you say wrap the wire around the spade lug and plug it back in. I have seen to many problems with doing that on the smaller fuses. I would recommend one of these. Cooper Bussmann/ATM fuse tap (BP-HHH-RP) | Fuse and Accessories | AutoZone.com These are a lot safer I feel
I've never had issues but in sure what you suggested is safer!
Old 10-29-2013, 01:38 PM   #10
Tyoung68's Avatar
You just need a test light. Open the cover theres a little bit if the metal prongs from the fuse so use the test light and find one that doest have power when the keys off and then turn the key on and see if it has power after and then you can either buy a fuse tap or just strip the wire and shove it in with the fuse then hook up the leds and then your done!
Old 10-29-2013, 02:39 PM   #11
Sparkz's Avatar
wow, thanks man, this helped a whole lot!
Old 10-29-2013, 02:53 PM   #12
Tyoung68's Avatar
No problem! Thats what we are here for
Old 10-30-2013, 01:39 PM   #13
Sparkz's Avatar
if I strip the led wire, do I need to ground the negative wire? (Might be a stupid question)
Old 10-30-2013, 01:51 PM   #14
im pretty sure that you do. what are you putting the power wire to?
Old 10-30-2013, 01:53 PM   #15
Sparkz's Avatar
fuse box
Old 10-30-2013, 01:59 PM   #16
Tyoung68's Avatar
Yes you have to ground the negative wire
Old 10-30-2013, 03:52 PM   #17
qccoles's Avatar
I've had my dash open so much, I could probably take it apart in less than 3 minutes. It's been ran from my headunit for a while now. I ran the ground wire from the LED with the ground(black wire 90% of the time) from the headunits harness. I ran the power wire from the LED with the headunits 12v/ignition(red wire in my case). NOT THE CONSTANT 12v(yellow in my case), or else the LED's will be on even when the car is off, which you will not want..
Works great and positioned correctly, it will not bother you at all when you're driving. I'm using a Sony XAV601BT. Let me know if you need any help.
EDIT: Forgot to mention, my LED's came from walmart. Yes, walmart. I'm not a fan of paying 2-4 times the price to order from someone like american muscle. I'm COMPLETELY satisfied with my LED's. 18 bucks and a half an hour install. Couldn't be happier.
Old 11-01-2013, 09:10 PM   #18
Sparkz's Avatar
Just want to give a big thanks to all who helped out, it looks sick!
Old 11-01-2013, 09:29 PM   #19
purple?
Old 11-01-2013, 09:53 PM   #20
Sparkz's Avatar
purple?
Of course, it is my favorite color.
Old 11-01-2013, 09:56 PM   #21
pretty sweet
---------- Post added at 10:56 PM ---------- Previous post was at 10:55 PM ----------
Mine was fuscia before I changed it to red
Old 11-01-2013, 10:06 PM   #22
Tyoung68's Avatar
Looks good!
Old 11-02-2013, 11:41 AM   #23
qccoles's Avatar
How'd you end up wiring it? The only con about these are they amplify dirt for our DD's ;[
Old 11-02-2013, 12:27 PM   #24
Sparkz's Avatar
I wired it into the fuse box, I'll vacuum my car every day for these if I need to
10:10 PM
