Plasti Dip rims (Help!) - Mustang Evolution
Old 11-13-2013, 03:04 PM   #1
tapwater1's Avatar
So I am wanting to paint my stock 2005 V6 silver rims with black plastic dip. What is the best way to do this? Could I cover the tires with wrap and brakes, and then clean the rims with alcohol and then do a few coats? Just need help starting out, appreciate it. If y'all don't mind giving me a detailed plan.
tapwater1 is offline   Reply With Quote
Old 11-13-2013, 04:01 PM   #2
If you have access to jack stands just take them all off and spray them on the floor. Will make it so much easier without having to cover your car or brakes with tape. You also don't need to cover the tires themselves, plasti dip won't stick to the rubber, so when its done it literally comes off of the tires with no effort.
Old 11-13-2013, 04:02 PM   #3
This is how i did mine.... Of course you will want to cover the floor underneath the tires with newspaper or something.
ID:	136341   Click image for larger version
Old 11-13-2013, 05:52 PM   #4
tapwater1's Avatar
That looks like it turned out very well! I only have one jack.. So any other way, would just be to over everything I guess. Appreciate the help. How many coats and cans did you use?
Old 11-14-2013, 09:58 AM   #5
Billd25's Avatar
I left mine on the car and just covered the brakes with newspaper and covered the lug nuts with tape. The plastidip will peel right off the tire.
ID:	136454   Click image for larger version
Billd25 is offline   Reply With Quote
Old 11-14-2013, 12:17 PM   #6
tapwater1's Avatar
Very impressive, both of you. All you did was tape the brakes? Seems too simple
Old 11-14-2013, 12:31 PM   #7
Billd25's Avatar
It really was simple. My 6 year-old helped me with covering the brakes and taping the lug nuts.
Make sure the first coat is light, to get the dip to stick better.
If you tape the lug nuts and valve stem, remove the tape immediately after each coat, so the dip won't get stuck to the tape and peel off.
I did 4 coats of black plastidip and 3 coats of glossifier (half a can). The glossifier really makes a difference in getting the wheels to shine and not be flat black.
I also did my hood scoop and rear deck panel with plastidip.
Watch some videos here: https://www.youtube.com/channel/UCsq...2RLo8peD11olPw
Old 11-14-2013, 01:14 PM   #8
tapwater1's Avatar
Very cool. I only have 2 cans, should that be enough? And for the decklid panel, I have a different paint but I'm assuming I should use a sand block on that and my stock spoiler as well. Just making that black as well with some risers for it.
Old 11-18-2013, 05:09 PM   #9
tapwater1's Avatar
Thanks for the tips guys, you all helped. I finished it and it looks pretty damn good.
Old 11-20-2013, 10:10 AM   #10
Raphael's Avatar
Not hard just cover up the brakes and rotors and just spray
Raphael is offline   Reply With Quote
Old 11-20-2013, 10:21 AM   #11
tapwater1's Avatar
I can't use tire shine because it seems to stick to the paint. Any advice? To all.
Old 11-20-2013, 10:40 AM   #12
Zhim's Avatar
I use tire shine foam on the tires then wipe off any over spray I get on the rims with wet rag. U could always cut a template and hold it as you spray to cover up the rims. If u use the brush-on kind, just slow down and cut in carefully. go figure lol
Zhim is offline   Reply With Quote
Old 11-20-2013, 10:42 AM   #13
I love the way both of these cars are done
---------- Post added at 11:42 AM ---------- Previous post was at 11:41 AM ----------
Attachment 136992
Attachment 136993
Attachment 136994
came out great OP!! looking good
Old 11-20-2013, 11:45 PM   #14
2 Stangz's Avatar
Region: Nevada
I wouldn't trust just covering the brakes and rotors. My dumbass friend 'dipped his wheels on his 2011 Sierra and got overspray all on his paint around his wheel wells/fenders. Luckily that sh*t comes off with a little elbow grease and buff pad.
Old 11-26-2013, 05:09 AM   #15
c_walsh97's Avatar
c_walsh97 is offline   Reply With Quote
Old 11-26-2013, 09:02 AM   #16
tapwater1's Avatar
What year is your stang? We have pretty similar rides.
Old 11-26-2013, 09:17 AM   #17
Zhim's Avatar
When I dipped my wheels I decided to challenge myself a bit and masked off the rim and just dipped the spokes
Old 11-26-2013, 09:23 AM   #18
tapwater1's Avatar
How long did that take you!
Old 11-26-2013, 09:58 AM   #19
Looking good c_walsh97
Old 11-26-2013, 10:03 AM   #20
Zhim's Avatar
I took all four wheels off. Washed in and out and dried maybe 20 min. 10-15 min/wheel for masking then sprayed 2 fast coats on each wheel and peeled the tape. However by the forth wheel the dip had already started drying and taking the making off would peel the dip too so u had to score along the tape line with a thin razor. If anyone's planning to do this then either have a helper to peel the tape or do 2 at a time
Old 11-26-2013, 12:15 PM   #21
c_walsh97's Avatar
2007 and yea we both do lol
Old 11-26-2013, 03:35 PM   #22
tapwater1's Avatar
Pretty rad
Old 12-03-2013, 01:03 AM   #23
I heard you should use at least 2-3 coats of plasti dip to protect from chips and stones
darendlal is offline   Reply With Quote
09:53 PM
