Replacement key - Mustang Evolution
Old 11-23-2013, 11:35 PM   #1
66Sprint200's Avatar
Replacement key
I know what you're thinking from the title, "just go to the dealer". Well, I've asked my question at the dealer and they didn't know.
What I want to know is, will one of the newer keys with the built in remotes work on a 2005? I know the keyblade is the same, but would the remote work?
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Old 11-24-2013, 10:23 AM   #2
JimC's Avatar
Some will. I couldn't get one to work on my 2006, but then tried a different one and had no problems.
JimC is offline   Reply With Quote
Old 11-24-2013, 10:26 AM   #3
ive got one of these for my 05
Ford Replacement Keyless Remote Fob Flip Ignition Transponder Chip Key Combo | eBay
---------- Post added at 11:26 AM ---------- Previous post was at 11:26 AM ----------
Old 02-10-2014, 06:57 AM   #4
how do you like the flip key skoundrel? I've thought about it alot, but wasn't sure if it would be a good quality or not.
Old 02-12-2014, 12:12 AM   #5
Kustumb's Avatar
How do you sync these things to the car?
Kustumb is offline   Reply With Quote
Old 02-12-2014, 01:22 AM   #6
You have to have both your factory keys. You put the first factory key in, turn the ignition to "ON" for more than one second and less than 10 seconds, turn the ignition off, and within 10 seconds put the second factory key in and again turn it ON and leave it for at least one second and less than 10 seconds. Now within 20 seconds of removing the second factory key, insert the new unprogrammed key and turn it to on. Leave it there for more than a second. And it should be programmed. Surprisingly all of that is in our owner's manual.
Old 02-12-2014, 02:22 AM   #7
Kustumb's Avatar
**** both? I only have one. And I meant the remote, not the key?
Old 02-12-2014, 07:34 AM   #8
Oh to program the remote you only need one key. Get in the car, close the door, turn the key to "ON" and put on seat belt (to turn off all the warning dings). Now turn the key off and on 8 times (should end with the key in "ON") and the door locks will actuate. Hit the unlock or lock button on the remote. Tah dah, programmed.
04:50 AM
