Heat problem - Mustang Evolution
Old 12-01-2013, 06:55 AM   #1
LivelyMustang's Avatar
Heat problem
Hey so on my 05 my heat works when I'm on the highway, but when I drive below like 50 mph my system only blows out cold air. Any ideas?
LivelyMustang is offline   Reply With Quote
Old 12-12-2013, 05:43 PM   #2
Air pockets in your coolant ?
mustbstangin is offline   Reply With Quote
Old 12-12-2013, 06:57 PM   #3
yugoboss's Avatar
First thing is check your coolant level is full. If
It is try a thermostat.
yugoboss is offline   Reply With Quote
Old 12-12-2013, 06:59 PM   #4
mark_ash0426's Avatar
That sucks i have the opposite problem lol
mark_ash0426 is offline   Reply With Quote
Old 12-13-2013, 08:19 PM   #5
yea i flushed the coolant and replaced the thermostat and now everything is good to go. Thanks guys
Old 12-14-2013, 07:20 AM   #6
Make sure you got all the air out to prevent air pockets and overheating
Old 12-14-2013, 10:31 AM   #7
Thanks dude
Old 12-14-2013, 08:21 PM   #8
samuelsmith's Avatar
Check the vacuum lines on the passenger side out the fire wall. The heater and ac ventilation system runs off vacuum lines. The external air can get stuck open without enough vacuum. vacuum pressure closes it.
Old 12-17-2013, 08:22 PM   #9
I got it fixed but I'm gunna take a look at that when I get a chance. Thanks
04:05 AM
