Start up issues. - Mustang Evolution
Old 12-03-2013, 10:30 AM   #1
MustangMandy's Avatar
Start up issues.
Hi everyone, so I have this issue with my 05 V6. Everytime I go to start it it makes this awful metal shanking sound and none of the gauges are lite up until about 3 seconds then everything turns on. And my factory radio is off then comes on and has reset itself. Any ideas anyone?
MM05V6
MustangMandy is offline   Reply With Quote
Old 12-03-2013, 12:16 PM   #2
satin06silver's Avatar
mine was doing somethin similar i replaced my battery and it seemed to fix it just take your battery to autozone or somethin to get it tested
“I don’t lose any sleep at night over the potential for failure. I cannot even spell the word.”
Gen. James "Mad Dog" Mattis USMC (Ret.)
satin06silver is offline   Reply With Quote
Old 12-03-2013, 02:21 PM   #3
Yeah I replaced my battery with an optima red top battery n I also replaced my alternator n it is still doing it.
MM05V6
Old 12-04-2013, 08:13 PM   #4
id start shotgun troubleshooting thats kinda weird whats happening ... is the motor running then everything kicks on or everything all at once?
Old 12-09-2013, 06:06 AM   #5
I turn the ignition and the car cranks over. Then when it is running about 3 sec later the instrument panel lights come on. Then another maybe 20 sec later the radio comes on and it has reset itself. Also it seems like my headlights kinda dim constantly while the car is running.
---------- Post added at 07:06 AM ---------- Previous post was at 07:05 AM ----------
I got my car @ an auction so I don't know a whole lot about my car.
MM05V6
Old 12-09-2013, 06:31 AM   #6
66Sprint200's Avatar
Just because you put a new alternator in doesn't mean you didn't get a bad one. With your car running, put a voltmeter (or a multimeter set to volts) on your battery terminals to see what voltage your getting. A cars battery should be charging at 13.5-13.8 volts. The dimming headlights makes it sound like your having an alternator/charging issue.
That or you have whats known as a "phantom draw". Something may be draining too much power while your car is sitting overnight and it's wearing the battery down to the point that it can just start the car.
How long do you have to crank before the car starts?
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Old 12-16-2013, 04:44 AM   #7
For about 5-6 seconds. And it also makes this rubbing metal sound every once in a while when I start it.
MM05V6
Old 12-21-2013, 01:52 PM   #8
stockchaser's Avatar
Sounds like you may have a starter problem(possible internal short in it). Have it checked/tested by a professional.
2009 V-6 MUSTANG PONY PKG.
stockchaser is offline   Reply With Quote
Old 12-30-2013, 11:04 PM   #9
Mustang_2005's Avatar
Yes pull the starter and have it tested.
Sent from my SPH-L900 using Mustang Evolution mobile app
Mustang_2005 is offline   Reply With Quote
03:14 AM
