Mustang Vinyl Stripes - Mustang Evolution
Old 12-09-2013, 01:07 PM   #1
Mustang_2005's Avatar
Okay guys im about to put new vinyl racing stripes on my mustang I would like some input on how to properly take care of them and is there any sort of protection I can put over them? Thanks!
Mustang_2005 is offline   Reply With Quote
Old 12-09-2013, 05:53 PM   #2
TorchRed6's Avatar
ive heard your not supposed to wax over them. the only way id know of for protection would be to have a clear wrap put over them.
TorchRed6 is offline   Reply With Quote
Old 12-09-2013, 06:13 PM   #3
Getn off's Avatar
Don't wax for a couple weeks is all. Use a spray wax after washing, but before shammying, then wipe dry. Leaves a great protection on everything.
Troy
Getn off is offline   Reply With Quote
Old 12-09-2013, 07:39 PM   #4
So spray wax the stripes themselves or the whole car?
Old 12-09-2013, 07:42 PM   #5
Getn off's Avatar
After a couple weeks, the whole car. U can use reg wax too, but no compound...too abrasive.
Troy
Old 12-09-2013, 07:45 PM   #6
AmericanBulldog's Avatar
There's really nothing you can do that would be worth "protecting" the stripes. Vinyl isn't meant to be permanent, for that I'd recommend going the route of painting them.
AmericanBulldog is offline   Reply With Quote
Old 12-09-2013, 07:50 PM   #7
I would paint them but I plan on getting a new car in the next 2 years and its not worth the money to me.
Old 12-09-2013, 07:53 PM   #8
2 years? Then don't worry about them. If they are good vinyl they would last you at least 5 years.
Old 12-10-2013, 06:46 AM   #9
Getn off's Avatar
Ur correct, but UV will hasten the aging of even 3m vinyl. Using a coating of UV protectant, ie wax, will make it last years longer than advertised duration. Personal experience with stripes, and boat decals in Florida.
Troy
Old 12-10-2013, 07:54 AM   #10
What kinda wax and what brand would you suggest?
Old 12-10-2013, 08:23 AM   #11
Troy
It technically would make it "look" like it is lasting longer... but what I don't know is if the glue will be affected at all because the glue in the end is what decides if it will be a pain to remove. since the longer it stays the worse the glue gets.
Old 12-10-2013, 09:29 AM   #12
Getn off's Avatar
U use Maguieres and have great luck. They have a 3 step process that works awesome. There are better, more expensive, waxes out there, but I can't tell the diff once waxed between them. They have a great yellow wet wax that is easy and quick. Quick detail spray I think its called.
Troy
Old 12-10-2013, 09:56 AM   #13
Troy
Thank you sir I will definitely be trying this.
07:15 PM
