2005 Mustang v6 - Mustang Evolution
Old 01-01-2014, 07:14 PM   #1
2005 Mustang v6
Just replaced all the spark plugs. idle is at a steady 900. For some reason, rather I'm in reverse or drive she shakes like crazy and hesitates when trying to accelerate. other than a vacuum leak, what else could this possibly be?
Dash_Jetson is offline   Reply With Quote
Old 01-02-2014, 01:57 AM   #2
Mustang_2005's Avatar
Do you have any mods done to the car? Any engine lights come on?
Sent from my SPH-L900 using Mustang Evolution mobile app
Mustang_2005 is offline   Reply With Quote
Old 01-02-2014, 04:11 AM   #3
JimC's Avatar
Double check and make sure you have the wires going to the correct spark plugs.
Then, make sure your wires are properly seated on the plug. When you installed the new plugs did you start them in by hand first, and then use the wrench? If not, you may have cross threaded a plug. Can you hear any hissing type sounds?
JimC is offline   Reply With Quote
Old 01-02-2014, 06:37 AM   #4
yes, i have an engine light on. took the car up to Autozone to get checked out, they said either spark plugs or vacuum leak.
---------- Post added at 07:37 AM ---------- Previous post was at 07:35 AM ----------
No, not getting a hissing sound, she's just really shakey, sounds and feels like the car wants to turn off.
Old 01-02-2014, 11:56 AM   #5
I would recheck all the plug wires first and if they are all good then pull the plugs and check them.
Old 01-02-2014, 02:13 PM   #6
JimC's Avatar
If you have a CEL what code was brought up? That will pinpoint the issues
Sent from my SPH-L720 using Tapatalk
Old 01-10-2014, 02:06 PM   #7
cj92's Avatar
Way kind of plugs did you use I got some from Autozone for my f150 they sold me the wrong ones they ended up being to short made it run like ****
Sent from my glade plugin
cj92 is offline   Reply With Quote
Old 01-13-2014, 10:19 AM   #8
Lmo36's Avatar
Is it manual?
Current Vehicle: 2012 Black Mustang 3.7 with a k&n 69 typhoon sieries CAI Ford racing Strut tower brace Forgestar f14s on the way 😈 | Past vehicles Ford ranger | 2001 Jeep Wranger | 2007 White v6 mustang |
Lmo36 is offline   Reply With Quote
Old 01-14-2014, 05:46 PM   #9
jek57's Avatar
I would start with the plug wires sounds like you have them crossed up .Did u take one off at a time when u changed your plugs? Easy to do been there done that before
jek57 is offline   Reply With Quote
Old 02-24-2014, 04:20 PM   #10
themauler's Avatar
Make sure they're gapped to spec too, sometimes they will not fire correctly
themauler is offline   Reply With Quote
Old 02-26-2014, 09:02 AM   #11
LivelyMustang's Avatar
I didn't think you had to gap your plugs?
LivelyMustang is offline   Reply With Quote
Old 02-27-2014, 12:06 PM   #12
themauler's Avatar
In theory they should come gapped already, but often they can get a little bit off set by the time you install them
Old 02-27-2014, 01:04 PM   #13
Hmm. Never knew. Thank for that info
2005 mustang
11:37 PM
