starting issues - Mustang Evolution
Old 01-24-2014, 01:09 PM   #1
starting issues
2009 V6 automatic about 58,000 miles new battery.
This is my daily driver. But it sat outside for the past 3 days with snow and temperatures in the 20s and 10s.
Went to start it this morning and it turns over like it will crank but suddenly stops and does nothing. The charge on the battery is great starter is good and alternator is good. Needing help !!!!
I'm car savy but this doesn't make sense to me .
kimmybrooke08 is offline   Reply With Quote
Old 01-26-2014, 02:02 PM   #2
Blakhwk's Avatar
Sometimes the coolant can cause this problem, it will freeze in cold weather. Make sure it has the correct spec coolant.
Visca Barça
Blakhwk is offline   Reply With Quote
Old 02-01-2014, 12:54 PM   #3
Unrivaled's Avatar
Listen for your fuel pump when you turn your key. Car might not be getting any gas
Unrivaled is offline   Reply With Quote
Old 02-12-2014, 07:46 AM   #4
Lmo36's Avatar
Also check that the plugs on the coil are all plugged in
Current Vehicle: 2012 Black Mustang 3.7 with a k&n 69 typhoon sieries CAI Ford racing Strut tower brace Forgestar f14s on the way 😈 | Past vehicles Ford ranger | 2001 Jeep Wranger | 2007 White v6 mustang |
Lmo36 is offline   Reply With Quote
Old 02-12-2014, 11:56 AM   #5
05MUSTANG4.0L's Avatar
With the car off :loosen up the negative terminal of the battery, then Turn on the car, unhook the terminal and wait Around 30 seconds to a minute. If the car turns off is definitely the alternator, this happened to me to. The test said that the alternator was good but when I did that it turned out that it wasn't
05MUSTANG4.0L is offline   Reply With Quote
Old 02-15-2014, 06:09 AM   #6
Hi
jsmarecz29 is offline   Reply With Quote
Starting in the cold issues Jgill1992 2005-2010 Mustang GT 14 11-12-2012 03:33 PM
Starting issues 351mustang 1979-1995 Mustang GT 100 01-03-2012 06:17 PM
starting issues RENDON713 1979-1995 Mustang GT 4 12-16-2011 07:49 AM
starting issues bostang99 1996-2004 Mustang GT 15 12-07-2011 10:46 AM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
06:42 PM
