Uneven lowering - Mustang Evolution
Old 01-25-2014, 12:56 PM   #1
Bschmidty's Avatar
Uneven lowering
So a few weeks ago I got my SR springs installed (1.5" drop) along with my pan hard rod and alignment bolts.
About 2 weeks ago I went up a curb trying to get out of a tight parking spot and I noticed that the rear right side measured 7 1/2" from the top of the rim to the fender. But the left measured 6 1/2". A week later i guess the springs settled and it measured 7" on both sides. But now it's back to the way it was before. Is this common? Should I take it back to the shop? And will this keep happening?
Bschmidty is offline   Reply With Quote
Old 01-25-2014, 06:34 PM   #2
Kustumb's Avatar
May have not installed correctly but fell into correct placement after driving it abit.
But take it back just to make sure, you shouldn't get charged for faulty installation.
Kustumb is offline   Reply With Quote
Old 01-26-2014, 11:33 AM   #3
Lmo36's Avatar
Did you install them your self?
Current Vehicle: 2012 Black Mustang 3.7 with a k&n 69 typhoon sieries CAI Ford racing Strut tower brace Forgestar f14s on the way 😈 | Past vehicles Ford ranger | 2001 Jeep Wranger | 2007 White v6 mustang |
Lmo36 is offline   Reply With Quote
Old 01-26-2014, 11:52 AM   #4
Rollins7's Avatar
How long have you had them installed when you measured, but if your height is moving i woulf def get under it and check it out
Rollins7 is offline   Reply With Quote
Old 01-26-2014, 01:40 PM   #5
Bschmidty's Avatar
No I had a shop install them. I asked them about the problem and they said it was common for that to happen. But I'm gonna take it in again and see if they'll fix the problem
Old 02-08-2014, 07:45 PM   #6
Lmo36's Avatar
Make sure that the springs are installed with the grooves that the stock ones have put in
Old 02-12-2014, 07:39 AM   #7
Lmo36's Avatar
Originally Posted by 99ford View Post
I've always wanted a lower vert because lowered verts look dope
Do it!
Lowering car JohnC. 2005-2010 Mustang GT 10 02-01-2012 03:35 PM
Lowering questions Camo1967Mustang Pre-2005 V6 Mustang 12 12-06-2011 01:46 PM
Lowering the 04 stang ArmyScout 1996-2004 Mustang GT 31 10-10-2011 09:29 PM
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 09:32 AM
Mustang lowering Jesse Bach General Car Discussion 4 08-01-2011 12:09 PM
04:26 PM
