Transmission problems - Mustang Evolution
Old 03-29-2014, 08:21 AM   #1
I have a 2005 base mustang 6 cylinder with an automatic transmission. The reverse does not work when the car is cold works better when car is warm. The over drive light is flashing. Do i need a new tranny.
brent5258 is offline   Reply With Quote
Old 03-29-2014, 09:09 PM   #2
G3ARH3AD's Avatar
How many miles also those cars have a 5r55s trans which are not the best imo but od light usually means over heating temps but can b just electrical, but since ur reverse only works when it warm sounds like a bad seal for that part
G3ARH3AD is offline   Reply With Quote
Old 08-30-2015, 03:55 PM   #3
dorkdog's Avatar
Sorry to revive an old thread but enough is enough!
It has been mentioned several times in several laces that these are supposedly 'sealed units' because they have no dipstick? Yet, I have also discovered that they have a drain port AND a fill port - that does not follow my definition of a 'sealed unit'. There has also been confusion as to how often the trans should be serviced - 30K or 80K?
I will add to this confusion by relating that I had my AT fluid checked when I bought my 2010 V6 in May 2015, with only 40K, and the fluid was 'just starting to turn'.
dorkdog is offline   Reply With Quote
Old 08-30-2015, 06:56 PM   #4
JokerS197's Avatar
Yeah the new trans don't have the dip stick. The only way to do anything transmission wise is if you have the trans fluid injector hose thing. I believe the manual says ever 80k, I drained it once.
JokerS197 is offline   Reply With Quote
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
Transmission problems Hons67 2.3 Mustang 5 05-30-2011 04:16 PM
Auto transmission problems. 6opka Pre-2005 V6 Mustang 4 04-18-2009 02:38 PM
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
06:10 AM
