Car vibrates when idle - Mustang Evolution
Old 04-07-2014, 01:30 PM   #1
It all started when i was trying to get out of some snow, smoke started flying from under the hood and from the exhaust and the engine light was on. I took it to 3 different mechanics. The first two told me it was a blown head gasket, and they were gonna charge me an arm and a leg to repair it. The 3rd mechanic told me it was the thermostat gasket that needed to be replaced, not a blown head gasket. So i went with the 3rd mechanic and got it done, plus he did a tuneup for me. When i picked my car up all the smoke from under the hood and exhaust was completely gone. One problem i noticed now though is my car will vibrate every couple seconds when I'm parked(idle). My question is what is most likely the problem? I got the thermostat replaced and a tuneup done. Again, it only vibrates every few seconds in idle, when I'm driving there is no type of shaking whatsoever. Thanks.
LanceStone is offline   Reply With Quote
Old 04-08-2014, 04:35 AM   #2
Region: Asia
I were had enginge vibrates when idle/move, after I change my spark plugs & ignation coils/Wires become stable & got better response. Stock parts replaced by Iridium IX,
,Screamin' Demon Coil, LiveWires. hope thats help.
Regards..
Stang 2006 V6
Mods:
octane 95,3-CORE BOLT-ON ALUMINUM RADIATOR+TRANSMISSION OIL COOLER,NGK Iridium IX,
Auburn Gear 542023 Auburn Gear HP Series Limited Slip Differential,Screamin' Demon Coil LiveWires,Motive 4.10 Gears, JLT Next Generation CAI and SF3 Tuner, more to come
KKatto is offline   Reply With Quote
Old 04-10-2014, 06:19 AM   #3
08Mustang's Avatar
My car does the exact same thing. Considerably more noticeable in extreme cold. I've changed my coil pack to the Accel one, I've got Taylor street thunder 8mm wires, and iridium plugs so tht doesn't fix the problem. I did notice that my airaid airbox was vibrating against the fender quite a bit and I fixed that and it really toned down the amount of vibration I would feel at idle
08Mustang is offline   Reply With Quote
car vibrates on highway bradh2414 Pre-2005 V6 Mustang 10 08-17-2012 11:28 PM
86 5 speed vibrates when giving gas at idle lilrafe87 1979-1995 Mustang GT 10 04-20-2012 10:15 AM
Clutch pedal vibrates and makes a vibrating noise at the low 1000 - 2000 rpms and? finley 1996-2004 Mustang GT 2 12-12-2011 06:33 AM
I have a 1975 Mustang II that vibrates a little.? dumont75 Classic Mustangs 5 08-23-2009 02:34 PM
Steering wheel vibrates back and forth dark Pre-2005 V6 Mustang 9 12-20-2007 07:17 PM
12:18 PM
