Removing door panel HELP!! - Mustang Evolution
Old 04-12-2014, 05:52 PM   #1
I'm installing puddle lamps and I had to put my door back on because I couldn't get the door pull cable to come out. Supposed to squeeze two prongs and pull out, but I as well as another guy couldn't get it.
Anyone else have this problem? Idk what to do..
Thatdude156 is offline   Reply With Quote
Old 04-14-2014, 08:02 AM   #2
66Sprint200's Avatar
If you are trying to get the door panel off, the easiest way is to just leave the door pull on the door and just remove the panel (I did this yesterday to fix a rattle in my passenger door). Once you get the door panel loose (with the door handle still attached to it), reach around the back, unplug the door lock switch. Here you have the choice to either pull the door lock switch out of the door (I'd recommend it), or try popping the door handle assembly out with it still in place (risks pulling the back plate of the switch assembly). Once you've decided what to do there, you can pop the door handle assembly out of the panel, and slide it through the door panel, freeing the panel from the car. I hope this helps.
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Door panel insert help. primer2tone 2011-2014 Mustang GT 21 04-30-2016 08:40 AM
Please help! need to remove instrument panel left side panel Peruano_loco 2011-2014 V6 Mustang 5 02-02-2014 09:24 AM
Removing outside door handles v8pony 1996-2004 Mustang GT 2 02-13-2013 10:20 PM
86 svo mustang header panel wanted header panel? wit 2.3 Mustang 1 08-21-2009 08:39 PM
Removing Door Panels? McGrail482 Mustang Audio & Video 5 06-05-2004 09:51 PM
11:53 AM
