Problem filling car with fuel - Mustang Evolution
Old 04-13-2014, 08:02 AM   #1
tjpfab's Avatar
I have a 2005 V6 convertible that about 75% of the time is a pain in the neck when trying to put fuel in it. The pump will keep clicking off until I end up holding the fill nozzle at about a 90 degree angle and let it just barely drizzle in. Sometimes it takes me 15 minutes just to fill it. It is all very inconsistent between pumps, weather, etc. Anyone else have this problem? Solution?
Sent from my SCH-I925 using Mustang Evolution mobile app
tjpfab is offline   Reply With Quote
Old 04-13-2014, 08:04 AM   #2
CrystalSn95's Avatar
I had a similar problem with my explorer, it ended up being a purge valve that Lernout excessive air pressure while filling. Cleaned the valve and no issues sense.
CrystalSn95 is offline   Reply With Quote
Old 04-13-2014, 08:05 AM   #3
Chadtyge's Avatar
Fuel tank pressure sensor
Chadtyge is offline   Reply With Quote
Old 04-14-2014, 10:39 AM   #4
66Sprint200's Avatar
Is the little flap still in the top of the fuel filler on yours? I ask because I had a similar problem last week. Filling up was almost impossible and I noticed the little flap was missing. Figured it was blocking the tube, pulled the filler tube and it wasn't there, felt inside the gas tank opening, pushed in on the check valve there and heard a plop as the plate fell into my tank (where it will stay, lol). Havn't had trouble since.
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Old 04-15-2014, 06:22 AM   #5
Yep on cars getting older the flapper will stick. If its sticky you can start filling really slowly and try to increase the flow gradually to get it to pop open. Not sure I would want a piece of flapper floating around in there like above but its probably not going to hurt anything. Permafix is to drop the tank and pull the fill neck and replace the flapper.
Old 04-15-2014, 06:30 AM   #6
tjpfab's Avatar
Pretty sure my flapper is fine so I think it might be the fuel pressure sensor as mentioned previously. Good idea to check it though...
Old 04-15-2014, 11:55 AM   #7
Blogger
99ford's Avatar
Dang it I thought I posted in here but sometimes the app messes up.
Ford put a TSB out on this. I think the remedy is to replace the connecting hose neck from the tank to the (filler inlet) not quite sure what they call it.
Some people have said turning the pump upside down is better.
Old 04-15-2014, 12:23 PM   #8
FullyAutomatic's Avatar
Region: Mexico
because mustang
Name:	mustang-gas-fill-meme-generator-hold-nozzle-upside-down-to-fill-because-mustang-24be3d.jpg
FullyAutomatic is offline   Reply With Quote
Old 04-15-2014, 12:31 PM   #9
Loc: Austin,TX
Had this problem on my 05 but I fixed it.
SOLD
Old 04-15-2014, 12:40 PM   #10
Region: Mexico
I have this issue. some times all you can give her is the tip
Old 04-15-2014, 12:56 PM   #11
mystang50's Avatar
SOLD
bahaha!
Old 04-15-2014, 01:13 PM   #12
Region: Mexico
just go to gas stations that are full serve and listen to the pump click off every 5 seconds lol
Old 06-03-2014, 01:19 PM   #13
natestang07's Avatar
I have had the same issue since I have got my car. It is a pain but I don't mind much.
Sent from my LG-E970 using Mustang Evolution mobile app
Old 07-02-2014, 08:15 PM   #14
Gravydog316's Avatar
Attachment 160645
Old 07-04-2014, 02:24 AM   #15
H1tmanevets's Avatar
I thought I was the only one that looked dumb for fueling with the nozzle upside down.. How big are your tanks? Mine stops at 12. I've heard it should be 16.
Sent from my VS980 4G using Mustang Evolution mobile app
H1tmanevets is offline   Reply With Quote
Old 07-04-2014, 06:54 AM   #16
tjpfab's Avatar
It will fill to 16 gallons but it just takes a long time because of the fill issue.
Old 07-04-2014, 08:23 PM   #17
How can I fix this?
Old 07-04-2014, 10:49 PM   #18
Originally Posted by H1tmanevets View Post
How can I fix this?
you have to replace everything.
Old 07-06-2014, 11:37 AM   #19
Yeah not doing that. Just went on unemployment. I don't have income anymore. I'll stick to a 12 gallon tank I guess.
filling the tank problem.. Andy714 2005-2010 V6 Mustang 17 12-11-2012 03:34 AM
Filling t5 Quball19 1979-1995 Mustang GT 3 05-22-2012 01:59 PM
help-filling diff, getting aggravated..... rinfield2004 SVT Mustang 15 12-05-2011 09:36 AM
Fuel Filling Problems on 67 Mustang jmbalch Classic Mustangs 2 06-22-2011 12:29 PM
Start Filling Out Your Garage Today! Brent ME Site Help & Announcements 31 09-05-2010 10:30 PM
12:09 AM
