Over heating and antifreeze? - Mustang Evolution
Old 06-02-2014, 09:17 PM   #1
Evangreco118's Avatar
My car was over heating today and making an odd squeaking sound, so I parked it and I smelled what I believe to be anti freeze. Any thoughts?
Evangreco118 is offline   Reply With Quote
Old 06-05-2014, 03:09 PM   #2
Terminator's Avatar
Where exactly was the squeaking coming from
Terminator is offline   Reply With Quote
Old 06-05-2014, 03:42 PM   #3
I couldn't pinpoint it, but it sounded like the transmission area
Old 06-07-2014, 04:49 PM   #4
jek57's Avatar
Sounds like the water pump is going
jek57 is offline   Reply With Quote
Old 08-12-2014, 11:39 AM   #5
Check your thermostat housing. If that's bad then any coolant will leak on the side of the engine.
Boxxer is offline   Reply With Quote
Old 08-12-2014, 12:07 PM   #6
Bschmidty's Avatar
Is the thermostat gauge fluctuating? If it is it could be the thermostat housing. Check under throttle body area for fluid leaks and it could be a water pump problem
Bschmidty is offline   Reply With Quote
Old 08-12-2014, 12:14 PM   #7
I had a similar problem, if you coolant disappears without my seen leaks from hoses, check the radiator and thermostat housing. I have a squealing problem also after my car overheated. It still squeals, I'm going to check on my water pump.
over heating and power loss wootman101 Pre-2005 V6 Mustang 0 12-12-2013 11:24 PM
68 302 over heating??? 68dnixcoupe Classic Mustangs 7 05-01-2012 06:54 PM
Over heating Contourdrew 1979-1995 Mustang GT 1 12-23-2011 02:39 AM
Over heating Joshfelder 2005-2010 Mustang GT 5 06-04-2011 11:10 AM
Please Help...I'm going in circles. New engine, over heating and missfiring. rob4292 1996-2004 Mustang GT 4 05-31-2007 02:15 PM
09:20 AM
