Get I want to do this to my car but don't know where to get it HELP - Mustang Evolution
Old 07-09-2014, 07:17 PM   #1
MustangPooh's Avatar
Name:	ImageUploadedByMustang Evolution1404954937.087371.jpg
ID:	161052 where can I but those led blue lights from cheap please . And is that the only thing I need to make my speed things blue? Post the link to the led blue lights if you guys know thanks a lot
Mustang Evolution
MustangPooh is offline   Reply With Quote
Old 07-09-2014, 07:17 PM   #2
Buy*
Mustang Evolution
Old 07-10-2014, 04:38 AM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Originally Posted by MustangPooh View Post
Attachment 161052 where can I but those led blue lights from cheap please . And is that the only thing I need to make my speed things blue? Post the link to the led blue lights if you guys know thanks a lot
Mustang Evolution
I hope you have a good bit of electrical experience because you'll need to solder the leds directly to the gauge cluster circuit board where the factory lights currently are. What your picture shows is a car that has the MyColor (or whatever it was called on the 05-09s) option which let's you change the color of you gauges with the press of a few buttons. I would look into whether or not a gauge cluster with the MyColor is a direct plug and play. If so, you might be able to find one cheap and not have to deal with disassembling your current cluster and possible damaging something.
By the way, the "speed things" are called the speedometer and tachometer.
2012 Kona Blue 3.7L V6:
Old 07-10-2014, 05:03 AM   #4
bucko's Avatar
I'd agree with WhoDat....soldering anything onto a circuit board requires a bit of electrical savy; not hard to do, but would require a solder tool (easily bought from Radio Shack), some solder, and a sucking tool to remove the solder when removing the existing led's that are on your current guage cluster.
Acluster that is equipped with the "MyColor" option may be swapable into your Mustang. I know this was an option on the 2011 to 2014 Mustangs, so perhaps Ford offered it on the 2005 to 2010's as well. If it was, then removing your cluster, and replacing with one that has this feature might work. However, on the 2011 to 2014's, the buttons to program the color are on the dash, so this may also be an issue (do you have these?). Another issue is that the mileage from a donor cluster will not match your true mileage, and I do not think most states allow you simply swap a cluster without legally having the mileage flashed to match yours. Then again, most do not care to be complient with such things.
So, maybe just de-soldering and soldering in new leds would be the easiest...
Old 07-10-2014, 06:25 AM   #5
Thanks ya and lol @whodat I'm just going to leave it like that I have a V6 Mustang 2007 so I don't think it has the Mu color thing because the 3 buttons that the 08 mustang has is a hard piece with no buttons
Mustang Evolution
I don't want to.... but I will M3to5.0 2011-2014 Mustang GT 4 01-27-2012 10:09 PM
I want to buy a 2003 Mustang Convertible, but I don't know if its a good deal...? Faing General Mustang Discussion 2 12-13-2011 06:05 AM
Don"t ask ford, they don't know dacriss 2011-2014 Mustang GT 11 03-08-2011 08:10 PM
I want to get a car, but I don't know what one to get, any suggestions? arnett5 General Car Discussion 2 03-22-2010 01:12 PM
Don't know where I found it, but here. DropTop_Stang The Bar 1 10-20-2003 08:35 PM
11:16 PM
