Caliper Piston Stuck - Mustang Evolution
Old 07-27-2014, 04:38 PM   #1
Blogger
99ford's Avatar
My rear caliper piston will not turn in.
Old 07-27-2014, 04:41 PM   #2
Zhim's Avatar
Lube up the rubber on the side and press down while turning
Sent from my SGH-I727R using Mustang Evolution mobile app
Zhim is offline   Reply With Quote
Old 07-27-2014, 04:48 PM   #3
Blogger
99ford's Avatar
We will see if that works both sides are just stuck. I'm not sure if it is the tool I'm using or if the caliper is shot
Old 07-27-2014, 04:49 PM   #4
Zhim's Avatar
Stuck as in wont even turn?
Old 07-27-2014, 05:01 PM   #5
Blogger
99ford's Avatar
Yes it won't even turn!
Old 07-27-2014, 05:11 PM   #6
Zhim's Avatar
What is your tool like? I just use an attachment that goes on my socket wrench. The initial turn takes a lot of elbow grease then it eases up.
Old 07-27-2014, 05:12 PM   #7
Blogger
99ford's Avatar
I'm just using the loaner tool from autozone
Old 07-27-2014, 05:19 PM   #8
JoeyM91's Avatar
Couple things:
1) Make sure your master cylinder cap is off under your hood, helps release some of the pressure. Not doing so, you can damage the lines and the Master cylinder. Not to mention it will just be harder to compress.
2) Make sure you're using the tool with the "teeth" or pegs. The reason being is those teeth go into the indentions you see on the piston. It HAS to turn and press against the piston all at once or it will NOT budge and you'll just tear up the tool.
Old 07-27-2014, 05:39 PM   #9
Blogger
99ford's Avatar
Originally Posted by JoeyM91 View Post
Couple things:
I've done all that noting is working this thing is stuck.
Now the parking brake snapped in half a while ago.
Would that cause the issue?
Old 07-27-2014, 05:45 PM   #10
JoeyM91's Avatar
Might try putting a small pipe over the handle to get some leverage. If it's still not breaking loose past that if you're turning it the correct way, your pistons are probably frozen up.
If that's the case, you could have them rebuilt but it may be cheaper to get new calipers.
Old 07-27-2014, 11:36 PM   #11
Aventador97's Avatar
Same thing happened to mine a while back. It was the right rear caliper, so I just upgraded to slotted and drilled all around the car and new calipers. (Excuse the dirt on the rims)Click image for larger version
Name:	ImageUploadedByMustang Evolution1406525715.937675.jpg
ID:	162391Click image for larger version
Name:	ImageUploadedByMustang Evolution1406525745.716095.jpg
2003 Lamborghini Murcielago
2007 V6 Mustang (manual), Hurst/FR short throw, MAC dual exhaust, custom H-pipe, chin spoiler, GT front bumper, billet aluminum grill, GT500 rear bumper, GT500 wing, FR windshield banner, FR strut tower brace, LED interior lights, sequential taillights, FR side markers, slotted and drilled brakes, 93 Cobra teal painted (and cleared) stripes, etc.
Aventador97 is offline   Reply With Quote
Old 08-11-2014, 09:36 PM   #12
Blogger
99ford's Avatar
Thanks for the advice y'all. I got the bleeder open and a really strong guy to turn the tool, and it went back in. So at this point I'm not going to replace them.
Old 08-12-2014, 02:12 PM   #13
Nice
Boxxer is offline   Reply With Quote
Rear caliper piston 02PONY 1996-2004 Mustang GT 2 08-08-2012 09:39 AM
Stuck Brake Caliper deadsp0t 1979-1995 Mustang GT 17 07-20-2012 08:29 AM
Can the spring tabs on a brake pad be bent to accomodate a different caliper piston? telfor General Mustang Discussion 4 04-05-2010 11:42 PM
PBR Dual-Piston Caliper Part Number? Cope Pre-2005 V6 Mustang 6 11-24-2009 10:57 AM
Major Wiseco Piston PROBLEM! *DUW** plstktnkr2 Pre-2005 V6 Mustang 3 07-21-2003 02:58 PM
02:14 AM
