Spark plug wire problem - Mustang Evolution
Old 08-01-2014, 06:17 PM   #1
Bschmidty's Avatar
Hey guys. So my car has been sputtering and it got to the point where the CEL came on. I looked under the hood and saw that a clip holding the wires broke. Therefore it looks as if one of the wires may have been burned and I am thinking that is why my car is sputtering like that. I have after market wires on there so I plan on putting my stock ones back on. Could the wire be the problem? And if so is there a diagram showing where all the clips to the wires are placed? Any help is appreciated
Bschmidty is offline   Reply With Quote
Old 08-01-2014, 07:19 PM   #2
jek57's Avatar
jek57 is offline   Reply With Quote
Old 08-01-2014, 07:24 PM   #3
jek57's Avatar
Sounds like you might be missing a clip . You can buy clips at auto zone .Yes that would do it if it got burnt.
Old 08-02-2014, 05:02 PM   #4
Bschmidty's Avatar
Replaced the wires back to the oem ones.. There still is some sputtering. Could it be a fuel problem? Maybe spark plugs/coil pack?
Old 08-04-2014, 07:02 AM   #5
08Mustang's Avatar
When was the last time you changed your spark plugs? And fuel filter? And last time you ran some injector cleaner?
08Mustang is offline   Reply With Quote
Old 08-04-2014, 10:02 AM   #6
Bschmidty's Avatar
My fuel filter hasn't been changed. Looks like I found the problem. One of the oem wires had a bent "boot" (I guess you wanna call it) that went into the coil pack and left a gap. So it wasn't completely on hahah don't even know how I didn't notice that. Thanks for the help guys
Old 08-04-2014, 11:19 AM   #7
08Mustang's Avatar
Glad you found the issue!
Old 08-04-2014, 05:28 PM   #8
jek57's Avatar
Glad you got it fixed
Old 08-04-2014, 07:12 PM   #9
Bschmidty's Avatar
may not have been a loose wire after all. Plugged my oem wires back into the screamin' demon coil pack and that's when it started to sputter. But runs fine with the stock coil pack. Doesn't make sense to me but it's all good! Thanks guys
Old 08-04-2014, 09:00 PM   #10
08Mustang's Avatar
Apparently you've got a bad coil pack sounds like
Spark plug wire diagram Mike V. General Mustang Discussion 5 02-02-2014 11:38 AM
Coil pack and spark plug wire replacement 2000v6stang Pre-2005 V6 Mustang 5 09-01-2013 11:56 AM
spark plug wire. Audicrashdummy 2005-2010 V6 Mustang 7 01-30-2013 12:21 PM
Ford Racing 9mm Spark Plug Wire Problem 95GTease 1979-1995 Mustang GT 3 07-17-2012 03:10 PM
Spark Plug wire Clips RollinonGT 1996-2004 Mustang GT 1 12-12-2011 01:07 PM
02:35 AM
