Auto Tranny Problems - Mustang Evolution
Old 08-18-2014, 08:16 AM   #1
08Mustang's Avatar
So ever since I went to the track last Friday night my tranny has been acting up. Doesn't like to shift into 2nd, will wind it out pretty far until it'll shift under hard and normal acceleration. When in 5th gear the car would repeatedly change between 4th and 5th gear especially on hills while still under the same amount of throttle. And starting last night leaving the meet my car wouldn't go into 5th gear whatsoever...overdrive kept flashing that it was off. Used my tuner to pull the codes however no codes were being thrown on the gauges. But the codes I read were a PO775 pressure solenoid B, and two others I can't remember the codes but said Gear 2 Wrong Ratio and the other Gear 5 Wrong Ratio..........FML . I think I need a new solenoid pack and a fluid flush. What y'all think?
08Mustang is offline   Reply With Quote
Old 08-18-2014, 09:10 AM   #2
natestang07's Avatar
Could be the lovely servo bore issue. Look up the tsb for servo bores and maybe give the borebros a look.
05 Gt Premium Performance White, flowmaster outlaws
Old 08-18-2014, 09:11 AM   #3
08Mustang's Avatar
Servo bore?
Old 08-18-2014, 09:41 AM   #4
08Mustang's Avatar
Nevermind I looked up....how much for the repair?
Old 08-18-2014, 02:09 PM   #5
http://m.ebay.com/itm?itemId=271469797803
---------- Post added at 01:09 PM ---------- Previous post was at 01:08 PM ----------
Technically you only need the intermediate one repaired if it is the bores but I would do both.
Old 08-18-2014, 02:19 PM   #6
08Mustang's Avatar
Just dropped it off at my mechanics...extended warranty should be covering the repair
Old 08-19-2014, 01:59 AM   #7
My extended warranty literally didn't cover anything on my previous car. Hope yours goes better! Let me know of it is the bore issue I'm curious.
Old 08-19-2014, 09:14 PM   #8
08Mustang's Avatar
Tranny is completely toast....fluid came out black and not even a hint of red! The solenoids and intermediate and overdrive bands all started to go causing the fluid to be sectioned off and some parts that were getting lube cooked the fluid in there and the other parts that weren't getting fluid started seizing and destroying themselves basically.....extended warranty guys are supposed to come look at the car in the next couple days so I turned the car back to the stock tune and took off my Bama plaque and put on the stock airbox to make it as stock as possible so they'll possibly and hopefully overlook the modifications......however even if the warranty does cover the tranny then Ford won't have one for the next 3 weeks. The whole situation is a big mess
Old 08-19-2014, 09:23 PM   #9
08Mustang's Avatar
Name:	ImageUploadedByMustang Evolution1408504999.719211.jpg
Sitting in the lot at the shop today
Old 08-19-2014, 11:55 PM   #10
It took about a month for my warranty company to inform us they wouldn't cover my engine. After that we had a new one shipped and dropped in in 3 days, hopefully yours goes better
Old 08-20-2014, 06:39 AM   #11
08Mustang's Avatar
What all would be require to convert it to manual? If this ends up coming out of my pocket then I might as well put in a transmission id rather have lol
Old 08-20-2014, 07:28 AM   #12
Harness clutch flywheel assembly transmission of course
Old 08-20-2014, 07:30 AM   #13
08Mustang's Avatar
Would I need a new PCM? And I guess I would just use the clutch pedal assembly and line from a manual donor car?
Old 08-20-2014, 07:31 AM   #14
Pcm no and a donor car would make things a hell of a lot easier. I would say it is worth it personally if you have to replace it regardless
Old 08-20-2014, 07:32 AM   #15
08Mustang's Avatar
Yeah I figure it probably won't come out to be much more expensive....so how would I tune the PCM for a manual tranny?
Old 08-20-2014, 07:38 AM   #16
I actually read somewhere that it learns by itself. There was a thread somewhere about a guy doing it for like 1400$. I will look for it real quick.
Old 08-20-2014, 07:39 AM   #17
08Mustang's Avatar
Yeah I'd definitely appreciate that
Old 08-20-2014, 07:40 AM   #18
http://m.ebay.com/itm/03-04-MUSTANG-...-/120829543502
---------- Post added at 06:40 AM ---------- Previous post was at 06:40 AM ----------
I wonder how close that is to what you need
Old 08-20-2014, 07:41 AM   #19
08Mustang's Avatar
Yeah that's for an 03-04 car. I don't know
Old 08-20-2014, 07:48 AM   #20
http://www.allfordmustangs.com/forum...procedure.html
---------- Post added at 06:48 AM ---------- Previous post was at 06:47 AM ----------
That is a pretty solid write up. Again not the right year but it is something at least
Old 08-20-2014, 07:56 AM   #21
http://www.fbperformance.com/Technic...TB-E-AODE4R70W
Old 08-20-2014, 07:57 AM   #22
Alright man getting closer. I think that is perfect for you, just replace that transmission they have listed.
Old 08-20-2014, 09:02 AM   #23
08Mustang's Avatar
Thanks!! Just out of curiosity, will the TCI street fighter torque converter work on the v6 auto? I know it's the same trans but on AM, they only show fitment for a GT
Old 08-20-2014, 10:20 AM   #24
That I don't know about
Old 08-22-2014, 02:53 AM   #25
TTmustang10's Avatar
I know our trans is the same as a gt just weaker and different bell housing. I had a custom torque converter made for my 6
TTmustang10 is offline   Reply With Quote
Auto tranny VS. Manual tranny x2bittz Classic Mustangs 15 06-29-2013 07:07 PM
Auto Tranny Problems PoeWalker 1996-2004 Mustang GT 5 06-13-2013 06:44 PM
auto tranny problems 245ciPony 2005-2010 V6 Mustang 4 06-23-2012 01:14 PM
v6 tranny to a v8 tranny 97V6stangct Pre-2005 V6 Mustang 4 02-04-2012 12:42 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
07:56 PM
