Gaining power through bolt ons plus some - Mustang Evolution
Old 09-29-2014, 09:27 AM   #1
thevanman's Avatar
Just curious if it is possible to beat the 4th generation GTs with some bolt ons and a little more? I have the screaming demon coil pack and CAI. I plan on adding pypes mid muffler true dual exhaust, rebuilding the rear end with an auburn LSD and 3.73 gears, 70mm throttle body, and a spec stage 2 clutch with aluminum flywheel. I know I would need about 260hp. Is there anything else not on this list, other than FI, that would add some good hp, or torque?
Sent from my HTC One_M8 using Mustang Evolution mobile app
thevanman is offline   Reply With Quote
Old 09-29-2014, 10:21 AM   #2
Bschmidty's Avatar
Full bolt ons with a good tune will get you around 210 rwhp. Translates to around 250-260 hp at the crank. I would get 4.10's if I were you and possibly long tubes and a ported intake manifold
Bschmidty is offline   Reply With Quote
Old 09-29-2014, 10:29 AM   #3
thevanman's Avatar
Can't do the long tubes. I heard the 4.10s have pretty bad gas mileage. This car us my daily driver, but I know this engine is able to really put down some power.
---------- Post added at 04:29 PM ---------- Previous post was at 04:28 PM ----------
Do you know of a good place for the ported intake manifold?
Old 09-29-2014, 10:35 AM   #4
Bschmidty's Avatar
True you'll see about 3 mpg loss at most with 4.10's. Also I would recommend getting an 8.8" rear end from a GT or 11+ v6. The auburn LSD is very expensive for what it is. Also the gear install would be easier for the shop since the rear end and differential is already out.
In terms of more hp/tq, you could always get some engine work done (cams/heads)
Old 09-29-2014, 11:45 AM   #5
08Mustang's Avatar
Yeah I put down 210rwhp with a cai, tb spacer, shorty headers, Pypes mid muffler catback, accel coil pack and a Bama 90 octane ethanol free race tune. I've added a throttle body and an o/r xpipe and some Taylor 8mm spark plugs wires since then so should be about 220rwhp now or so
08Mustang is offline   Reply With Quote
Old 09-29-2014, 07:13 PM   #6
thevanman's Avatar
I haven't found any good websites for performance cams and heads.
Old 09-29-2014, 07:33 PM   #7
Bschmidty's Avatar
Supersixmotorsports.com and stage3motorsports.com as well i believe
Old 09-29-2014, 08:03 PM   #8
thevanman's Avatar
Do the shortly headers add low end torque or high end? In your opinion which is more important?
Old 09-29-2014, 08:08 PM   #9
08Mustang's Avatar
Shorties add more low-mid range power....and if you're wanting all out performance then there's no other choice than long tubes
Old 09-29-2014, 08:09 PM   #10
thevanman's Avatar
Are the shorties worth it or will it still be a good gain with just the dual exhaust?
Old 09-29-2014, 08:11 PM   #11
08Mustang's Avatar
I like mine...good power and sound especially with a good dual exhaust. But if I had to do it over I would go long tubes honestly
Old 09-29-2014, 08:56 PM   #12
thevanman's Avatar
How would I go about passing smog?
Old 09-29-2014, 08:57 PM   #13
08Mustang's Avatar
You can't with long tubes...even with cats most likely he'll fail you due to relocating the cats
Old 09-29-2014, 10:01 PM   #14
thevanman's Avatar
How much hp does the cam add?
Gaining horsepower through bolt ons thevanman Pre-2005 V6 Mustang 17 10-05-2014 05:04 PM
bolt ons for more power sanhty69 2005-2010 Mustang GT 22 06-18-2013 10:13 PM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 02:45 PM
96 3.8l with some bolt ons whats next...? Need some advice please!!! Mavs32 Pre-2005 V6 Mustang 6 02-02-2011 04:56 PM
MM&FF (Muscle Mustangs & Fast Fords) V6 Bolt Ons Power Parts Tested Seph Pre-2005 V6 Mustang 22 05-28-2004 02:22 PM
10:08 PM
