HELP!! 06 v6 mustang not accelerating on taking off - Mustang Evolution
Old 10-29-2014, 11:31 AM   #1
My father owns a 2006 v6 mustang and its acting weird
when u are at the red light , you step on the gas and the car wont go anywhere
after 4 seconds, the car takes off spinning tires or just takes off fast ,
and it does that every time u stop and take off,its like the fuel is traveling very slow when u press the gas, and it takes like 4 seconds to get gas and then it takes off, this is dangerous becuz i can be at the shopping center trying to get out and i step on the gas to get in front of the cars coming and the car wont go , after 4 seconds the car takes off really fast and it can be too late in 4 seconds the traffic cars are going to be in front of me and im going to hit them .
wat can i do to fix this issue to prevent an accident from happening , i change the spark plugs and the wires and didnt help
any advice would be appreciate it
thanks
gt06ws602 is offline   Reply With Quote
Old 10-29-2014, 12:34 PM   #2
JimC's Avatar
So the engine revs up but the car doesn't move? That is a transmission problem, not a spark plug and wire issue.
JimC is offline   Reply With Quote
Old 10-29-2014, 01:00 PM   #3
the car wont even rev up or nothing it just sits there for seconds (when stepping on the gas pedal like 1/2" deep -taking off slowly mode)
it sits there and then after seconds the car takes off, and u can see reving up to like 3,000 rpm then changes to 2nd gear and the rev comes down to normal
Old 10-29-2014, 01:16 PM   #4
Throttle body?
Old 10-29-2014, 02:43 PM   #5
even if i slam on the gas pedal , the rpms stay at idling and after 3 seconds, it takes off
if its the throddle body , what can i do to fix it , spray carb cleaner????
Old 10-29-2014, 03:01 PM   #6
My friend has a similar problem with his 06, except his will literally die sometimes. He hasn't been able to find out what it is.
I'm not sure, I guess you could try cleaner
Old 10-29-2014, 03:26 PM   #7
yea this one also , idles really low on a stop , and wants to die, and sometimes it does, if u dont step on it , its stressful
Old 10-29-2014, 03:29 PM   #8
Throttle position sensor?
Wysh is offline   Reply With Quote
Old 10-29-2014, 03:39 PM   #9
hadenbyrd23's Avatar
Does he have a tune on it? One time my car did the same thing because it was a bad tune but I got it fixed.
hadenbyrd23 is offline   Reply With Quote
Old 10-30-2014, 11:57 AM   #10
well i took it to autozone and it came a code P0506 , which its Idle Air Control System RPM Lower Than Expected
i purchase a can of carburated cleaner and spray it to the troddle body while the car was on , and father stepping on the gas so it wont die while spraying , and when i was spraying , no black juice came out or i didnthrow any black smoke, it was clean already
i did notice while reving the engine on park to 4,000 RPM the engine bogs, at 3,000 its reving perfect smooth , but between 3,500 and 4,000 it bogs down to 3,500, and if i hold the gas pedal and keep it at 4,000 the rpm starts to rev up and down up and down up and down, between 3,500 & 4,000 , in other words it wont stay at a solid 4,000 rpm
the code says might be the PCV VALVE????????
should i take of the throddle and clean it, even though it seem clean from the outside ??????????
Old 10-30-2014, 01:35 PM   #11
Clean inside the TB if the inside is dirty, replace PCV. Do it right or you will keep having problems.
Old 10-30-2014, 02:19 PM   #12
Bschmidty's Avatar
http://www.brenspeed.com/tech.html here are tech videos on how to clean the throttle body correctly
Bschmidty is offline   Reply With Quote
v6 mustang
2013 v6 automatic mustang clunk when re-accelerating jerrysun 2011-2014 V6 Mustang 16 12-09-2014 12:58 PM
Not accelerating normally SkylerTallman_ Mustang DIY and Technical 8 06-30-2014 06:04 PM
HELP!!!! Weird rattling noise when accelerating! shawn.velez36 1996-2004 Mustang GT 6 05-01-2014 04:09 PM
1987 mustang 5.0 misfiring while accelerating? ethan 1979-1995 Mustang GT 5 12-23-2011 01:06 AM
Taking cats off 01 mustang? Joshy Pre-2005 V6 Mustang 37 02-08-2011 03:06 PM
07:13 AM
