Stereo install problems - Mustang Evolution
Old 12-31-2014, 11:29 PM   #1
So I just installed a double din Kenwood head unit into my 06 . I tested it after install and it seemed to work great. Once I got to driving and really turned it up it distorted horribly. I used a wiring harness from eBay and as far as I know all the wiring is right. Do you guys think its a mess up on my part or bad speakers , there are tweeters installed and I assume aftermarket component speakers ,along with 10 inch subs in the doors. This was all like this when I bought it . also I don't think the radio is as loud as the stock one was. Which didn't seem right to me. Any suggestions before I take everything back apart would be great :thumbup:
Sent from my XT1080 using Mustang Evolution mobile app
NcmustangboyIw is offline   Reply With Quote
Old 01-01-2015, 01:47 AM   #2
irishn8's Avatar
U may need an amp with those subs. What are the specs on all the speakers and radio?
Old 01-01-2015, 03:56 AM   #3
TTmustang10's Avatar
The doors are 8" not 10"? You need an amp to power the subs or it will sound bad same with speakers all the power is lost. Did you buy a wire harness to the battery with a fuse pack? Stock shaker 500 isn't that strong. I've had that problem needed to power 8"s with amp. Have a separate bass knob so the subs are separate from the speaker bass controls. If you have the volume control on the steering wheel you need a special kit to work with after market dash.
TTmustang10 is offline   Reply With Quote
Old 01-01-2015, 04:07 AM   #4
Name:	ImageUploadedByMustang Evolution1420110160.872197.jpg
ID:	172689Click image for larger version
Name:	ImageUploadedByMustang Evolution1420110213.842191.jpg
Kicker comp cvt 8"
Kicker amp cx600.1 and w/ bass knob
Old 01-01-2015, 06:22 AM   #5
Actually they are 10s? Like I said someone had them installed. And no I did not , I assume the previous owner was running the sub's off of a separate amp
Old 01-01-2015, 06:39 AM   #6
What lucky I've got 8"s to barely fit these are shallows, they didn't cut the back panel did they ?
Old 01-01-2015, 06:46 AM   #7
I'm not sure , I'll take a picture of them tho so you can see. They're pretty tight in there
Old 01-01-2015, 07:09 AM   #8
I think the panel behind them is cut
Old 01-01-2015, 11:24 AM   #9
Okay I see how they used a 10" if the panel is cut behind it, it's allowing to much air the subs need a closed environment my sound shop was explaining to me. Plus the power to support them
Old 01-01-2015, 12:37 PM   #10
irishn8's Avatar
The way subs work, u can have both vented or enclosed. Closed makes a crisp thud which most people like. Vented wont be as crisp, but it can be louder.
I can pretty much guarantee that you will need an amp unless the radio can put out enough wattage. Usually they put out between 100-200w though.
Old 01-01-2015, 12:49 PM   #11
So what is the lowest watt amp I can get to give these some depth. Because I've got two 12 inch rocford fosgates on the way so I just want these to have some sound
Old 01-01-2015, 04:22 PM   #12
irishn8's Avatar
Depends on the power requirements of the subs. If i were to guess, id say 500w if your regular speakers are 25w then u could run those right off the head, i gotta know what the output on the stereo and what the power requirements are on the speakers are before i can give you a good answer. U need to know what the wattage measurements are too - weather they are measured in peak wattage or RMS wattage. You want to match them up as best you can. Your amp should produce a little more power than your speakers so you arent running the amp at maximum efficiency all the time.
Old 01-01-2015, 04:29 PM   #13
Okay I'll look into it
Old 01-01-2015, 08:43 PM   #14
Okay so I believe the stereo is just 50 watt x 4 or however you say it. The common output for stereos. And below are the component speakers and the sub's for the front doors that I will have installed shortly. Like I said earlier. I just want the subs to have a good sound quality to them and I want to be able to crank the volume up without distortion
ID:	172728   Click image for larger version
Old 01-01-2015, 08:51 PM   #15
Okay our speakers all 4 are 6x8. The subs you'll need an amp with separate bass knob so the subs are independent from the speakers bass levels.
Old 01-01-2015, 08:53 PM   #16
Name:	ImageUploadedByMustang Evolution1420170791.300532.jpg
Old 01-01-2015, 08:54 PM   #17
My bad. Im used to my 2003's specs
Old 01-01-2015, 08:54 PM   #18
That's a really good deal for 10" I paid about 120 each for my 8"shallows.
Old 01-01-2015, 08:56 PM   #19
I've heard decent reviews about rf's stuff so I figured id try them out. And yeah I searched around a lot before I made a decision
Old 01-01-2015, 08:58 PM   #20
What do you think about Kenwood speakers ? I've never had any
Old 01-01-2015, 08:59 PM   #21
I'm not saying they are bad, they are a good brand and for 59.99 who couldn't pass that up. A good amp is planet audio I got a 3000watt for 175. Powers my big boy in the trunk.
Old 01-01-2015, 09:03 PM   #22
I love kicker speakers more. Check them out on Amazon.
Kicker 11ks68
Old 01-01-2015, 09:04 PM   #23
Name:	ImageUploadedByMustang Evolution1420171446.758624.jpg
Old 01-01-2015, 09:08 PM   #24
Name:	ImageUploadedByMustang Evolution1420171687.359024.jpg
Old 01-01-2015, 09:13 PM   #25
Name:	ImageUploadedByMustang Evolution1420171837.827122.jpg
ID:	172735Click image for larger version
Name:	ImageUploadedByMustang Evolution1420171959.308180.jpg
ID:	172736Click image for larger version
Name:	ImageUploadedByMustang Evolution1420172006.717810.jpg
Old 01-02-2015, 06:18 AM   #26
Will that 600 watt amp be enough to push my 10s adequately
Old 01-02-2015, 03:40 PM   #27
The amp should be good enough make sure you get bass knob and wire it separate for speakers
Old 01-02-2015, 04:09 PM   #28
After I get my components and tweeters replaced do you think I'll need an amp for those also
Old 01-02-2015, 06:44 PM   #29
The kicker have tweeters built in you don't need to buy extras.
Old 01-02-2015, 06:46 PM   #30
The speakers won't need an amp, but the subs will. Or it will continue to be distorted. Also remember have the sub base level separate from the speakers. Or when you turn bass up for doors it will control the speakers and make blow them easier. Also be easy on the speakers and sub for two week break in period. After that your good to crank her up.
Old 01-02-2015, 06:47 PM   #31
Okay, thank you
Old 01-02-2015, 06:58 PM   #32
No problem brotha, keep me posted hope it works for ya.
Old 01-02-2015, 07:28 PM   #33
irishn8's Avatar
I found some helpful articles for ya.
http://knowledge.sonicelectronix.com...-an-amplifier/
https://www.mtx.com/t/library-subwoofer-impedance
I hope you make a wise purchase
Old 01-02-2015, 07:32 PM   #34
I'll probably take it to my audio guy and let him worry about it
---------- Post added at 02:32 AM ---------- Previous post was at 02:31 AM ----------
But thank you for your input
Old 01-08-2015, 02:36 PM   #35
Well I've got my speakers in the doors replaced with pioneers and I have kickers in the back deck. Not the exact setup I wanted but had to go with what the store had. They sound great. Just waiting for them to get broke in. Oh and I found out all of the speakers minus one in the back and the subwoofers in the doors were blown. So my vocals were just coming through the tweeters added in the in the front lol
---------- Post added at 09:36 PM ---------- Previous post was at 09:36 PM ----------
In the pillars in the front *
Need help asap with Stereo install Scorpion1 Pre-2005 V6 Mustang 13 07-10-2008 01:34 AM
2001 gt mach stereo sub & amp install gwilkrrs Mustang Audio & Video 2 07-08-2008 06:09 PM
Complete Stereo Install! onetwin69 Mustang Audio & Video 2 03-27-2007 07:36 AM
2000 mustang stereo install?? stang00 Mustang Audio & Video 11 01-03-2006 02:28 AM
How to on stereo install lowflyn Pre-2005 V6 Mustang 4 11-13-2003 06:43 PM
12:32 PM
