Quarter window problem on my 07 v6 convertible - Mustang Evolution
Old 01-17-2015, 10:55 AM   #1
Well I have a problem with my quarter window on the driver side all the other windows goes up and down except for this one. This one can go down but when it goes up, it only goes up half way and gets stuck. I look all over the Internet on how to replace but can't find anything or videosClick image for larger version
Name:	ImageUploadedByMustang Evolution1421517304.449726.jpg
4pointOH is offline   Reply With Quote
Old 12-20-2015, 11:02 AM   #2
ANY LUCK?
I have the exact same issue with my 05 gt convertible. The driver side quarter window seems to have a problem with the track, as sometimes it will get stuck and not go all the way down or up. Can't find anything online! Anyone have any luck thus far?
bryjenk is offline   Reply With Quote
Old 12-21-2015, 11:18 PM   #3
Mean14's Avatar
I am thinking you might have to recalibrate the windows....
Taken from manual:
Short drop glass (Front windows only)
In order to improve door efforts and sealing, your vehicle is equipped
with short drop glass. This feature lowers the glass when either door is
opened. The glass returns to its closed position when the door is closed.
Proper operation of the short drop glass requires that the windows be
calibrated. Though your windows will have been calibrated before
your vehicle is delivered to you, it is possible for the windows to
lose calibration. If a window loses its calibration, your short drop
feature will lower the window, but will not raise it again when the door is
closed. To re-calibrate the window, pull the switch up to raise the
window until it completes its travel and hold the switch up for 2
seconds. Another possible effect of lost calibration is that the feature
may not lower the window. To re-calibrate the window in this case, lower
the window until it completes its travel and hold the switch down for 2
seconds. Immediately after releasing the window down switch, pull the
switch up to raise the window until it completes its travel and hold the
switch up for 2 seconds. Perform Short drop re-calibration with
doors closed only. Re-Calibrating with doors open will cause the
window to continuously bounce back.
Rear Power Windows (Convertible Only)
The rear quarter windows are operated by a single window switch
located at the Driver door window controls. Press and pull the window
switch to open and close the windows.
• Push down and hold the switch to open.
• Pull up and hold the switch to close.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
96 SVT Cobra Rear quarter window and rear window louvers. Any good ones? Spiney SVT Mustang 4 04-05-2012 08:41 AM
Convertible Quarter-Window Help? nickcap 1979-1995 Mustang GT 22 07-14-2011 06:41 PM
Quarter window NC8950 1979-1995 Mustang GT 3 09-25-2006 03:45 PM
quarter window powerhungry966 1979-1995 Mustang GT 10 09-06-2006 07:36 AM
Rear quarter window rattle SpectorV Mustang Audio & Video 2 03-30-2006 08:37 PM
03:39 PM
