Coolant leak - Mustang Evolution
Old 02-05-2015, 08:28 AM   #1
v6carolina's Avatar
Coolant leak
Hey guys my 2010 4.0 just started spraying coolant all down the passenger side engine bay? Is this most likely the thermostat cracked? Click image for larger version
Name:	ImageUploadedByMustang Evolution1423150065.295525.jpg
ID:	174922Click image for larger version
Name:	ImageUploadedByMustang Evolution1423150084.328574.jpg
ID:	174923Click image for larger version
Name:	ImageUploadedByMustang Evolution1423150106.561057.jpg
v6carolina is offline   Reply With Quote
Old 02-05-2015, 08:41 AM   #2
08Mustang's Avatar
Most likely....it's located next to the alternator and sorta under the throttle body. Check that
08Mustang is offline   Reply With Quote
Old 02-05-2015, 08:54 AM   #3
Texas22's Avatar
Yeah probably the thermostat housing. It's made out of cheap plastic
Texas22 is offline   Reply With Quote
Old 02-07-2015, 07:33 AM   #4
v6carolina's Avatar
So should I repair the o-rings or buy a new housing?
Old 02-07-2015, 08:33 AM   #5
JimC's Avatar
You have to replace the housing, it splits open. Can't replace O rings on it to fix it.
JimC is offline   Reply With Quote
Old 02-07-2015, 01:02 PM   #6
Texas22's Avatar
I completely replaced mine back in September. Parts only cost about 125-150, your local shop will probably do it all for like 300. Simple install if you want to do it yourself
Old 02-21-2015, 04:18 PM   #7
Joe_Roma5's Avatar
You can order an aluminum tstat housing and never have to worry about it again
'06 4.0 V6 custom x pipes, cai, screamin demon coil pack, 10mm live wires spark plug wires, NGK iridium plugs, 93 octane bama tune
Joe_Roma5 is offline   Reply With Quote
Old 02-22-2015, 01:15 AM   #8
TTmustang10's Avatar
Where did you purchase the aluminum one?
TTmustang10 is offline   Reply With Quote
Old 02-22-2015, 05:13 AM   #9
Joe_Roma5's Avatar
Can't remember, Sorry. Theres only one company that makes them though. If you google it I'm sure you can find it
Old 02-22-2015, 08:32 AM   #10
JimC's Avatar
Check on Amazon, he used to sell them there as well as on ebay.
Old 02-22-2015, 12:56 PM   #11
Thanks mate
Coolant Leak? BrKu789 1979-1995 Mustang GT 3 12-28-2010 08:40 AM
bad coolant leak jmachleit 1979-1995 Mustang GT 8 01-13-2010 04:31 PM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 08:40 PM
coolant leak inside car Racin02GT 1996-2004 Mustang GT 8 06-19-2006 06:19 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
10:41 PM
