Coil packs - Mustang Evolution
Old 03-19-2015, 08:24 PM   #1
Texas22's Avatar
Coil packs
So I've heard that cool packs work good when you also do plug wires and plugs with, but I've also heard they do nothing really. Anybody have them and can tell me the actual difference? Or what product brands they'd suggest? I see coil packs on AM claiming an 18hp gain which has to be a bunch of crap. What do Yall think?
Texas22 is offline   Reply With Quote
Old 03-19-2015, 08:28 PM   #2
TTmustang10's Avatar
If you buy one get screaming demon, I got accel coil pack wish I got the demon. Did seem to have better spark and faster start up got 10mm wires with mine. Looks good in engine bay.
Hope that helps
TTmustang10 is offline   Reply With Quote
Old 03-19-2015, 08:49 PM   #3
08Mustang's Avatar
Yeah I've got the Accel with Taylor 8mm wires and it definitely idles smoother and just runs smoother
08Mustang is offline   Reply With Quote
Old 03-19-2015, 10:19 PM   #4
Texas22's Avatar
Should I invest in it or just spend money on something else?
Old 03-19-2015, 10:20 PM   #5
Whatcha already got ?
Old 03-20-2015, 06:40 AM   #6
Texas22's Avatar
Performance wise: stock headers, catted x pipe and axel back, cold air and a tune
Old 03-20-2015, 07:12 AM   #7
fenixignition's Avatar
I dont know about the v6 coil packs, but the coil on plugs for the v8's, word is that motorcraft outperforms them all. a guy on the forum actually used some kind of load testing equipment to test em all, and the motorcraft are more durable, and better voltage made its way to the plug.
Just gotta figure in the fact that sometimes, any new coil might out perform an old coil. but oem tends to be the way to go. definitly no hp gains from a new coil except for reaching your original hp from when it was new.
another thing that goes for the v8 coils that im not sure about on the v6 is that most coils diagnosed as bad only needed a new boot, or a wire in your case.
Personally, i would spend more on quality wires, and make sure its quality and not just a name. again, id put my money on oem. Spark plugs, oem as well. The only time you really need to change plugs is if your boosting, or under heavy mods.
Hope this helps.
2002 GT 5sp. 16x,xxx miles
Old 03-20-2015, 08:11 AM   #8
JimC's Avatar
The stock 4.0 coil pack is very good and more than adequate for anything you do to the car. In fact many have found it outperforms the "upgraded" coil pack.
JimC is offline   Reply With Quote
Old 03-20-2015, 09:01 AM   #9
08Mustang's Avatar
I've always heard that about OEM coils....I probably noticed improvement simply because mine had 70k miles on it
Old 03-20-2015, 09:24 AM   #10
I usually reccomend starting cheap and working your way up. plugs, then wires, then coil pack. but if you can fund it, then nothin wrong with just replacing it all at once. but coils tend to last a pretty good amount of time.
Old 03-20-2015, 01:29 PM   #11
Bobert's Avatar
Can anyone confirm the 18hp gain I saw that statement too and thought to myself no way. But hey I'd like to know
Bobert is offline   Reply With Quote
Old 03-20-2015, 01:43 PM   #12
natestang07's Avatar
Absolutely no way lol. With a coil pack you will mostly notice a quicker start up and smooth idle. That is it
Old 03-20-2015, 02:10 PM   #13
Texas22's Avatar
Okay so I guess save my money and buy something else?
Old 03-21-2015, 03:54 PM   #14
no way in hell lol.
Gas? Lol. I currently want a panhard bar for my 02.
Sent from my LG-D800 using Mustang Evolution mobile app
Coil packs blackdreams15 1996-2004 Mustang GT 8 07-27-2011 11:31 AM
Coil packs Chasetucker 2005-2010 Mustang GT 20 02-08-2011 07:37 AM
Coil Packs 04_GT 1996-2004 Mustang GT 6 01-12-2011 08:05 PM
Aftermarket Coil Packs jimbullit 2005-2010 Mustang GT 13 12-13-2010 02:53 PM
msd coil packs installed stovalini69 1996-2004 Mustang GT 0 08-04-2006 10:20 PM
10:38 AM
