Antenna wire question - Mustang Evolution
Old 03-29-2015, 09:54 AM   #1
So I was installing an aftermarket radio in my stepdads 2009 mustang Gt with the shaker 500 and long story shirt the antenna wire got messed up now it doesn't work. Is there anyway I can change out the wire before he realizes its messed up? I can't find one when I search for one
Sent from my XT1080 using Mustang Evolution mobile app
NcmustangboyIw is offline   Reply With Quote
Old 03-29-2015, 09:56 AM   #2
And it also has built in satellite radio, I don't know if that makes a difference or not
Old 04-01-2015, 09:00 PM   #3
Nobody ?
Old 04-01-2015, 09:51 PM   #4
oxford5pointoh's Avatar
Pictures of the damage would be helpful. In my experience the antenna cable is several pieces before it gets to the antenna itself. Probably plugs into a female socket where it enters/exits the car. You will usually find a part number. But at the end of the day it's just an antenna cable. You can get one anywhere. Follow it and see where it goes and go from there.
Old 04-02-2015, 11:44 AM   #5
king_13's Avatar
How did it get messed up? You cut the wire, burned the insulation, etc
Sent from my iPhone
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 04-02-2015, 12:24 PM   #6
The end is messed up , because I forced it into an aftermarket antenna adapter. So now the end doesn't make a connection
Old 04-02-2015, 04:45 PM   #7
05MUSTANG4.0L's Avatar
Cut it as if you was doing it to your speaker box
05MUSTANG4.0L is offline   Reply With Quote
Old 04-02-2015, 08:42 PM   #8
So like strip the end off it to bare wire ?
Need to connect red wire to gray wire. clflorida Pre-2005 V6 Mustang 4 08-06-2013 06:46 PM
Antenna Question Mkolabin General Mustang Discussion 13 02-02-2013 03:58 PM
Antenna question CrimsonGT 1996-2004 Mustang GT 11 01-03-2012 01:46 AM
speaker wire size? among another question? Pascullon Mustang Audio & Video 10 02-08-2011 10:44 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
06:39 PM
