Suspension advice wanted please! - Mustang Evolution
Old 04-02-2015, 11:36 PM   #1
PF Stangs's Avatar
Hey crew,
Spring is here and it's time I dropped my 09 'vert but wanted to see what the consensus was regarding how far to go and what worked for you.
Here's what I'm planning and nothing is installed yet -
the car is sitting on stock 17 Bullitts
H&R SuperSport springs - 2" drop
GT500 strut mounts - supposedly helps get rid of the dreaded 'knocking'
Ingalls strut tower brace
and finally I am thinking to add either an adjustable panhard bar or a new set of Koni STR struts/shocks while I'm at it.
Anything you all can recommend or feel is not needed? Too many options out there (bumpsteer kit, control arms, sway bars, coil overs, braces, etc) and I don't have enough cash to throw at it all. I'm wanting to do the work at once and not have to keep adding stuff.
Daily driver, no track days for this car.
Looking forward to hearing back from you and thanks!
2009 V6 'vert
PF Stangs is offline   Reply With Quote
Old 04-02-2015, 11:54 PM   #2
seanz05shaker's Avatar
V6? Does that year have a rear sway bar? If not, I'd make sure that would be in the plans too.
Sent from my DROID RAZR HD using Mustang Evolution mobile app
seanz05shaker is offline   Reply With Quote
Old 04-02-2015, 11:57 PM   #3
I can't tell you how much it improves the handling.
Old 04-02-2015, 11:59 PM   #4
PF Stangs's Avatar
I had thought of a rear sway bar take-off from a GT. I don't think the 09 V6 has one so hoping a GT one would be cheap enough and be a direct bolt on...thanks for reminding me!
2009 V6 'vert
Old 04-03-2015, 02:24 AM   #5
You will need the adjustable panhard bar for sure to put rear back in line.
Teak 14 is offline   Reply With Quote
Old 04-03-2015, 06:27 AM   #6
08Mustang's Avatar
I think all convertibles come with a sway bar but I may be wrong....but yeah you'll need camber bolts too if you get GT500 strut mounts. Or just get caster camber plates
08Mustang is offline   Reply With Quote
Old 04-03-2015, 08:22 PM   #7
PF Stangs's Avatar
Thanks for the suggestions everyone. Did you install all of your suspension mods at once or was there a particular order things went on? I'll be waiting another half year if I have to keep scraping together everything you guys mentioned!
2009 V6 'vert
GT500 Throttle Bottle wanted Please Mustangguy13 2005-2010 Mustang GT 0 04-22-2013 07:23 PM
Hey stang experts, friend has an idea of an upgrade but wanted your advice ArmyScout 1996-2004 Mustang GT 4 11-06-2011 01:26 PM
First time Mustang buyer, advice wanted DarkHorse11 1996-2004 Mustang GT 7 05-22-2009 03:19 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
Hurricane Vicitm. Christmas Donations wanted. Please read svosaleen The Bar 4 12-06-2005 10:01 AM
03:06 AM
