Automatic transmission changing to Manual. - Mustang Evolution
Old 04-28-2015, 06:17 PM   #1
Hello! Mustang fanatics!
So I recently got a mustang 2010 v6 4.0 which I love but only down fall is that I got an Automatic. I wish I could have gotten the Manual version but unfortunately they did not have that model and I really needed a car and I got a great deal on it so any how after a few months of driving it I have decided to get the conversion but I cant seem to find the right site for the parts and just really want some directions on here.
1. If someone could point me to the right parts I would be for ever greatful! also I may supercharge my car so I need a manual that is strong and can withhold a lot of pressure or torque i guess?
2. What is the best oil for this engine I specifically want your guys opinions before I do my first oil change in the next couple days. I do get a free oil change at the dealer ship but I personally think it would be a massive WASTE because I know they put bare minimum **** quality into your engine.
3. I need some schooling on these cars cause I recently came from a completely different model and car name so I know nothing about Mustangs
Travis.
Travisrwr is offline   Reply With Quote
Old 04-28-2015, 06:22 PM   #2
Congratulations, on your car. But the best thing to do in your situation is sell it and get a manual trans car, doing the conversion will be a very big headache. Another thing get away for the dealership and don't look back...
Adventure till you drop
Recon is online now   Reply With Quote
Old 04-28-2015, 06:25 PM   #3
Well if I do get one that is Manual ill need to go through the dealership. Not exactly sure what you mean by get away from the dealership as in my oil changes?
Old 04-28-2015, 06:30 PM   #4
Another name for a dealership is rip off center, stealership, take your pick...
Old 04-28-2015, 06:34 PM   #5
whelp I came here for advice on parts not negative BS. Well I am done with this forum and website Good Job negative Nancy bye.
Old 04-28-2015, 06:38 PM   #6
natestang07's Avatar
Dealerships charge too much for everything. Recon works in a successful automotive shop so maybe listen to him.
Old 04-28-2015, 06:38 PM   #7
I'm not being negative at all. I'm being honest, if I offended you I apologize, it wasn't my intentions. But if I was in your shoes, I think I'd try and find a manual. Unfortunately with a manual you have more things that need upgrades, that with an auto...
Old 04-28-2015, 06:42 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
He did give you the advice you were looking for. The best way to get the manual you want is to sell your current car and buy one with a manual transmission. As for the dealership, he also made a valid point. 99% of dealerships are there to make money, not help you. It's a sad but true fact. As for what oil to use, what you use is largely dependent on what you're going to be using the car for. Daily driver, weekend toy, track car?
2012 Kona Blue 3.7L V6:
Old 04-28-2015, 06:42 PM   #9
Not so much offended I came here to ask what would be the best transmission to buy? Now I got the car for a cheap price so getting the transmission conversion would actually save me money still instead of finding one that is a manual. I just wanted a link and some advice on my car not advice to get rid of it. Im willing to spend the money.
Old 04-28-2015, 06:44 PM   #10
I drive this car to work everyday but I also sometimes drive like a ******* unfortunately I live in the country side so the roads are wide open for me to gun it as much as I want.
Old 04-28-2015, 06:52 PM   #11
Alright, if that's what you want, here's a brief list of what you'll need...
The manual trans mission
You will most likely need another driveshaft
A manual trans floor pan section, you will need to cut the auto floor pan out of the car and weld the manual pan in
A clutch kit including throw out bearing and other components
Your computer will most likely need to be re-flash for a manual trans car or even buy a new computer
You'll need a new pedal kit with clutch, you will most likely need to cut the firewall to install the pedals
To do all this on a professional level it will most likely cost around 9-10 thousand dollars, that's an estimate...
Old 04-28-2015, 06:54 PM   #12
Just get a used tr 3650. Find a totalled 2010 and get the pedal assembalies. As for everything else I don't know.
Old 04-28-2015, 06:59 PM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
MobilOne 5w20 or 5w30 should be more than suitable
Old 04-28-2015, 07:05 PM   #14
Or if you are willing install a better torque converter on your auto replace the two piece driveshaft with a one piece and put some gears in the rear. Install a shift kit and then supercharge your engine.
As an Automotive Technician, I recommend you keep it an auto or buy a manual car. If you convert your car to a manual, and come time to sell it you will take a big loss on it...
Old 04-28-2015, 07:08 PM   #15
I wouldnt mind keeping it auto I just assumed that the torque and horsepower I wanted would damage the auto tran.
Old 04-28-2015, 07:11 PM   #16
Autos will handle the power better than a manual will. That's one reason why people use autos in drag racing, torque converters will get more of your engines power to the ground than what a manual will...
If you are concerned with your trans then consider upgrading to a better auto trans...
Old 04-28-2015, 07:15 PM   #17
Now what numbers are you wanting RWHP wise?
Old 04-28-2015, 07:21 PM   #18
350 possibly 400
Old 04-28-2015, 07:24 PM   #19
I'd recommend you talk to one of the members on the forum. He has a twin turbo v6 and made the numbers you are looking for. His names is TTmustang10. Nate correct me if I'm wrong...
Old 04-28-2015, 07:28 PM   #20
oxford5pointoh's Avatar
Recon, have you done this before? I can't imagine the floor has to be cut. Ford made these cars with manuals, so in the interest of keeping costs down they make the trans tunnels the same. This swap shouldn't be hard if you use the stock trans. Really just need a wrecked one, swap what you need and then add anything aftermarket you feel you would need like a better clutch ect.
Old 04-28-2015, 07:31 PM   #21
After searching I found that these models are also already cut for manual if you wanted to make the conversion. So technically there is no need to cut anything really.
Old 04-28-2015, 07:36 PM   #22
Yeah recon likes to jump on here and spout off on things he doesn't actually know and leave you with these...........................................................................................................................................................................
Old 04-28-2015, 07:38 PM   #23
And you won't have to cut the firewall either for the pedals. That's ignorant
Old 04-28-2015, 07:38 PM   #24
You are correct I was mixing it up with another vehicle we did the swap on, after reading over an article I found it has a very good info on performing the swap. Now this might not be everything you need or be more than you need, it's on an older mustang. Just a general idea of what to put on the list...
http://www.stangnet.com/mustang-foru...-guide.783401/
Old 04-28-2015, 07:39 PM   #25
Yeah ttmustang10. He has had a lot of issues and is letting go of the car I believe. Not sure if they were tranny or engine issues or both though
Old 04-28-2015, 08:03 PM   #26
Hey man thanks alot. I felt earlier you were just kinda being negative but I guess I interpreted it wrong sorry and thanks for the great info
Sent from my SM-G900T using Mustang Evolution mobile app
Old 04-28-2015, 08:14 PM   #27
No, I'm trying to keep you away for people who just want your money and not to help you. But you have no need to apologize I did come on a little negative/harsh/brutally honest. Unfortunately as stated 99% of dealerships are there for your $$$ and not to really help you. A good friend of mine has a 14 F250 deisel, and it has an oil leak. It took our local dealership nearly 3 months to get it fixed, when it should've taken three days. If you are interested in seeing some of the cars I work on I have a thread located in general car discussion...
Old 04-28-2015, 08:27 PM   #28
Sure thing I'll surf over to it once I figure out how to properly work this site lol
---------- Post added at 09:27 PM ---------- Previous post was at 09:26 PM ----------
Thanks for pointing these things out man.
Old 04-28-2015, 08:39 PM   #29
I'll make it easy for ya here's a link...
TGR's Garage...
Old 04-28-2015, 08:44 PM   #30
That was the write up I was going to follow when I was looking into the swap
Old 04-28-2015, 08:47 PM   #31
You got an auto Nate!!?!??!???!!!!!??!?!?!?
Huh, thought it was a stick...
Old 04-28-2015, 08:52 PM   #32
TTmustang10's Avatar
Our numbers are about 330 safe, I broke my converter and screwed the input shaft and 2nd and 3rd gear. I made 383hp and 372tq on 10 pounds.
2010 auto v6 is what I have. Had a twin turbo kit. But selling it to just go back to stock.
Well almost stock, putting in long tubes, ported heads and cam grind. With cai and under drive pulley. I have 8.8 rear with 3.73 and one piece drive shaft. I'm getting the car back with in the next 2 months.
As for numbers of hp idk what ill make, I'll keep you posted. But our trans you can super charge and be safe at 300hp or turbo it just keep at 300. They don't make upgrades for our trans. As far as gears and input shaft wise.
If you get a tune you'll love the auto trans and one pice drive shaft.
TTmustang10 is offline   Reply With Quote
Old 04-28-2015, 08:55 PM   #33
My v6 was auto. My gt is a manual though.
Old 04-28-2015, 08:56 PM   #34
Ya know ya never sent me the pics of the parts in my email. I messaged you on youtube bro
Old 04-28-2015, 09:05 PM   #35
My bad man Been busy with my two jobs, haven't been able to go to the shop and snap shots of the parts. They are busy and I just can't walk in cause policies.
Auto to Manual Swap- Looking for a manual transmission for 2013 v6 Bdeysher21 2011-2014 V6 Mustang 27 12-25-2014 04:19 PM
Changing automatic shifter knob SliverStang 2011-2014 V6 Mustang 4 01-06-2013 11:29 AM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
changing automatic transmission fluid 007z28350 Pre-2005 V6 Mustang 8 08-30-2009 01:25 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
09:39 PM
