Zex Safe Shot Nitrous - Mustang Evolution
Old 05-04-2015, 06:04 PM   #1
Texas22's Avatar
Zex Safe Shot Nitrous Kit for your 2005-2010 Ford Mustang V6
Came across this and it looked a little interesting, a little nitrous shot for only $300 by a pretty reputable brand. Wondering what you guys think. Kinda wanna get it and buy the upgrade kit someday if I get bored with the 15-35hp. Worth it?
Texas22 is offline   Reply With Quote
Old 05-04-2015, 06:15 PM   #2
Bschmidty's Avatar
Not too knowledgeable about nitrous so my opinion might be discounted. I heard Zex isn't the best route to go. If you were to go nitrous go all out. Bottle heater, window switch, etc. I'm sure rapinator may chime in
anyway if you have a 7.5" rear end, it won't be able to handle the added power
Bschmidty is offline   Reply With Quote
Old 05-04-2015, 08:04 PM   #3
08Mustang's Avatar
The 7.5" can handle a small shot like that...the 7.5" can handle up to about 300hp as long as you're not running slicks
08Mustang is offline   Reply With Quote
Old 05-04-2015, 08:17 PM   #4
JimC's Avatar
Wow, I didn't know that RPM Outlet was still in business.
Nothing wrong with the Zex product, although that kit is lacking a lot of things. I ran a 75 shot of nitrous on a Zex kit on my 2006 for 2 years with no problems. You need to adjust the tune for the nitrous, it isn't just hit and go. Also, I can't tell if that is a dry kit for sure, but it doesn't look like it has the fuel solenoid and doesn't have the nitrous management unit that Zex uses to combine the fuel and nitrous solenoids in one box. With the 2005+ Mustang you want a wet kit; it adds fuel as well as nitrous rather than relying on your computer to recognize the need to add fuel through the injector. Last thing you want is to run lean while spraying.
Make sure you have a nitrous pressure gauge. It performs best at about 900lbs but as you use it the pressure will drop. You also need a window switch. Even with Zex saying that the nitrous management unit (NMU) will learn when you are WOT and not fire before, it will mis-read. Before I had the window switch installed I was lining up to make a pass. Took the RPM up to about 2,000 to stage and the NMU decided that was WOT and fired off. Spraying too low in the RPM range is what will kill the engine. So got the window switch and set it to 2,400 rpm (window switch blocks the signal to the NMU until you reach the preset RPM and then it "opens the window" to the NMU).
It is nice to have a purge so that you have fresh nitrous ready to go when you are going to use it. And a heater for the bottle for those cool evenings and early spring or late fall trips to the track. DO NOT use a torch to heat the bottle. That will weaken the bottle and make it prone to rupture.
And Bschmidty is right. When the nitrous hits it adds a lot of torque all at once. The 7.5 rear end will break under the torque. Plus, with the open diff you will have problems getting the power to the ground.
Nitrous is really a track only power adder. You can't leave it turned on all the time or your solenoids will fail from the pressure. Many state laws won't let you leave it on anyway, some require you to disconnect the bottle until you get to the track. And at $4 a pound for nitrous it will get very expensive to fill the bottle if you are using it for daily driving. I could get about 10 passes on a bottle before it was difficult to keep the pressure up.
JimC is offline   Reply With Quote
Old 05-04-2015, 08:19 PM   #5
JimC's Avatar
The 7.5 won't last long with many nitrous hits; too much added torque coming on hard and all at once. It isn't the HP it is the torque that will kill the 7.5. All it takes is a tune, CAI, and a pair of drag radials to break one - even if you try to build it up. Learned that the hard way. Plus with the open diff on the 7.5 you can't get the power to the ground once the nitrous hits.
Old 05-04-2015, 08:23 PM   #6
08Mustang's Avatar
The slicks is what killed you....street tires don't hook nearly hard enough and a bolt on 4.0 doesn't make enough to break the 7.5"
Old 05-04-2015, 08:24 PM   #7
08Mustang's Avatar
I understand what you're saying about nitrous and how makes such instant torque but honestly if doesn't run slicks I think he'd be just fine...even more so if he's got an automatic
Old 05-04-2015, 09:21 PM   #8
Texas22's Avatar
I appreciate all the input, I'm glad I asked before I bought
nitrous
ZEX Safe shpot system jek57 2005-2010 V6 Mustang 0 02-22-2015 02:05 PM
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
ZEX 82015 Dry Nitrous Kit For Sale-Texas downtime Mustang Parts for Sale and Wanted 7 04-19-2006 12:00 PM
04:24 PM
