rear axle swap questions - Mustang Evolution
Old 05-12-2015, 08:23 PM   #1
So I've been looking into putting an 8.8 rear axle with 4.10s from a 2001 explorer into my auto 2005 v6 mustang. the problem I'm having is that everyone I ask about it has given me a different answer some yes some no. So before I go ahead and buy it I wanted to make sure that it would in fact just bolt in like I've been told it will, so here are my questions.
1. will it directly bolt into the car? if not what needs changed?
2. if it does will I need any other parts like a flange? if so what one? link?
3. I'm doing this in order to stay away from getting gears swapped to save money(quoted 1300 for 4.10 gear install) will this be cheaper in the long run or am I better to just get gears installed?
4. What is the cheapest way to fix the speedo afterwords?
5. will the brakes from that axle fit on the mustang if not will the mustang brakes go onto that axle?
6. will the shocks go back in place easily?
7. if this won't work what other axles could I look into getting to achieve the new gear ratio for cheap wit direct bolt in.
Anyone that can help me answer this would be of great help and would be greatly appreciated, and if I'm being completely stupid for considering this let me know thanks!
*heres the link to the axle I'm thinking about getting. https://akroncanton.craigslist.org/pts/4951975720.html
05v6man is offline   Reply With Quote
Old 05-13-2015, 05:10 AM   #2
08Mustang's Avatar
No it's not going to bolt up at all....the 05-14 mustang had a completely different style rear axle setup with the three link panhard bar setup.
08Mustang is offline   Reply With Quote
Old 05-13-2015, 05:39 AM   #3
Ok thanks I wasn't sure I'd all 8.8s were the same. Saved me alot of hassle.
For Trade: Roush Axle-Backs for 13+ GT500 Axle-Backs SecretAgent Mustang Parts for Sale and Wanted 3 06-07-2014 06:41 PM
Rear Axle swap PRoss.20 Pre-2005 V6 Mustang 25 12-11-2013 10:45 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 04:16 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
12:34 AM
