Shakes after I hit 50 mph. - Mustang Evolution
Old 05-17-2015, 11:21 PM   #1
windveilblueV6's Avatar
Okay so I installed a tower strut bar and it feels like it should. Tight when I turn however I am getting a shaky feel when I am about 45 to 55 mph. I know I need a wheel alignment will this stop the shaking? Or is it a baring gone bad?
windveilblueV6 is offline   Reply With Quote
Old 05-17-2015, 11:22 PM   #2
Name:	ImageUploadedByMustang Evolution1431926542.006691.jpg
ID:	182830this is the tower strut bar.
Old 05-18-2015, 02:04 PM   #3
satin06silver's Avatar
An alignment should definitely help . . . if not therer are other things that could be causing the shakes
“I don’t lose any sleep at night over the potential for failure. I cannot even spell the word.”
Gen. James "Mad Dog" Mattis USMC (Ret.)
satin06silver is offline   Reply With Quote
Old 05-18-2015, 05:56 PM   #4
jek57's Avatar
Was your car shaking before you put the brace on?...If not check to see if your brace isn't on the engine itself ... I put one on my 09 and I was getting a vibration come to find out it was pushing the engine down a bit and wacked out the motor mounts
jek57 is offline   Reply With Quote
Old 05-18-2015, 06:04 PM   #5
08Mustang's Avatar
Yeah either an alignment or a wheel is out of balance
08Mustang is offline   Reply With Quote
Old 05-19-2015, 01:25 PM   #6
Hellish Horse's Avatar
Or...you could have a bad tire. Might be getting a bubble or something. Did you have to loosen the bolts on the Camber Plates to install the brace ? I don't have a brace so not sure how they go in. If you had to loosen those bolts you probably made the alignment off even more.
Hellish Horse is offline   Reply With Quote
Old 05-22-2015, 07:18 AM   #7
Found out what it was. Right ball joint and two front tires later. 555.31 later and back on the road. The left front lower arm with joint was never aligned correctly by the last guy I brought it to. So I will be purchasing a compression tool next time this happens and getting a wheel alignment after I am all set with new arms. But that won't be for a long time.
Car shakes when I hit the breaks? (Only sometimes) skylaar10 2005-2010 V6 Mustang 5 08-01-2013 04:07 PM
2009 Mustang hit from rear by car going 55 mph......? bizahalani General Mustang Discussion 3 12-17-2011 05:27 AM
2009 Mustang hit from rear at 55 mph......? brawley General Mustang Discussion 2 12-16-2011 03:19 PM
Car shakes after oil change on a 1966 Mustang? Vaiveahtoish Classic Mustangs 2 12-11-2011 04:16 PM
68 302 shakes badly at idle after T5 swap TEvans720 1979-1995 Mustang GT 6 05-14-2010 06:33 PM
07:23 AM
