Rev - Mustang Evolution
Old 05-31-2015, 10:39 AM   #1
smazen24's Avatar
Rev
How do remove the rev limiter
smazen24 is offline   Reply With Quote
Old 05-31-2015, 10:42 AM   #2
Project Pony's Avatar
With a tuner, but may I ask why you would want to?
[SIGPIC][/SIGPIC]
Old 05-31-2015, 11:09 AM   #3
smazen24's Avatar
For auto burnouts
Old 05-31-2015, 11:28 AM   #4
TTmustang10's Avatar
If you have a stock driveshaft that's not smart to remove it
TTmustang10 is offline   Reply With Quote
Old 05-31-2015, 12:08 PM   #5
smazen24's Avatar
Yo you have the same car as me i know u done work to it what have u done?
Old 05-31-2015, 12:18 PM   #6
natestang07's Avatar
My totally stock v6 could do brake stand burnouts no problem
Old 05-31-2015, 12:28 PM   #7
C&L CAI
Pacesetter LTs
X pipe
Pypes
2.5 cut outs dual
BMR tubular k member
Slotted/drilled rotors
8.8 w/ 3.73
One piece drive shaft
Bama tune[
ATTACH]183833[/ATTACH]
Name:	ImageUploadedByMustang Evolution1433096891.153955.jpg
Name:	ImageUploadedByMustang Evolution1433096921.641171.jpg
Name:	ImageUploadedByMustang Evolution1433096867.546524.jpg
Old 05-31-2015, 12:29 PM   #8
One wheel peel? If you really feel the need to do burnouts, at least swap the rear end or install a tlok so you can spin both. Nothing quite as embarrassing as leaving one tire mark down the road...or the strip.
[SIGPIC][/SIGPIC]
Old 05-31-2015, 02:40 PM   #9
JimC's Avatar
You don't remove the rev limiter to do a burn out. With the 2005-10 it is pretty easy to do a burnout, of course with the open diff you will only have a one wheel burnout. To make it easier just get the tires a little wet and they will spin.
Removing the rev limiter is not a good idea at all. With the interference style of valve set up the rev limiter is there to keep you from damaging the engine and have pistons and valves become one.
JimC is offline   Reply With Quote
94 rev limit sledgehammer Pre-2005 V6 Mustang 4 03-03-2008 09:16 PM
Rev Jesse Jackson says T.O.'s Punishment is too severe Brent The Bar 17 11-15-2005 09:22 PM
catless @ idle/rev tedness Pre-2005 V6 Mustang 25 07-17-2005 02:22 PM
nitrous and rev limiter 02whitestang Pre-2005 V6 Mustang 2 02-12-2004 08:04 PM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 11:25 AM
12:37 PM
