Terrible throttle response - Mustang Evolution
Old 06-17-2015, 06:27 AM   #1
ace05's Avatar
Whenever I hit the gas it takes a good couple seconds for the car to start going. The only time i can get it to go when I want it to is to lay the gas all the way down. Other than that I'm risking getting rear ended when I pull out in front of people. What can I do to fix this?
ace05 is offline   Reply With Quote
Old 06-17-2015, 06:31 AM   #2
Kevin.Cook
Guest
Posts: n/a
Try disconnecting the battery for an hour. Then go take it for a spin. Also, you can try disabling the traction control (if equipped).
Old 06-17-2015, 06:36 AM   #3
ace05's Avatar
Well I've had this problem for a while and have just never done anything about it. I've done both of those before and it never changed anything
Old 06-17-2015, 06:49 AM   #4
Kevin.Cook
Guest
Posts: n/a
Are you tuned? Also, check to make sure you maintenance is up to date. Clean out the throttle body, MAF, Spark Plugs (depending on miles), air filter, oil change, and run some fuel system cleaner. You car always runs best when everything is kept in tip top shape.
If you are tuned, I was going to suggest to contact your tune vendor. If you are Auto, sometimes there is a lag when they are not tuned because the ECU has to adjust and downshift to the best gear at that time. Whereas with a Manual, you shift and it is instant.
A tune can help decrease the lag. Just depends on what you are aiming for.
Old 06-17-2015, 07:15 AM   #5
ace05's Avatar
Maintenance is all up to date. It's not tuned so that could work and I haven't cleaned out the throttle body. It only does it when I'm stopped and pulling out somewhere
Old 06-18-2015, 06:10 AM   #6
08Mustang's Avatar
It's just the nature of the drive by wire system and especially if you're an auto then that'll cause even more lag
08Mustang is offline   Reply With Quote
Old 07-14-2015, 07:30 AM   #7
Enorym's Avatar
Is it throwing any codes is your check engine light on?
Enorym is offline   Reply With Quote
Old 07-14-2015, 07:10 PM   #8
ace05's Avatar
No it just takes a second or two to get going after I press the pedal
Old 07-15-2015, 04:52 AM   #9
shunc01's Avatar
I used to have an 05 before and what I did is I did was disconnected the battery for 30 mins and put it back in or do KAM RESET you can do it in your sct device, or best solution is change your gears.
MPT TUNE, Borla S-Type, Airaid Cai, Ford racing X pipe, Mac ceramic shorty headers, 2010 GT500 rims, 35% tint, Sr Springs, J&M phb, camber bolts, blacked out side markers, front and taillights.
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 07-15-2015, 06:10 AM   #10
08Mustang's Avatar
My car has full bolt ons, 93 tune, and 3.73 gears and even after I had to unplug my battery the other day even my car had better response. It's good to do every now and then
Old 07-15-2015, 06:26 AM   #11
Will unplugging the battering have the same affect as a KAM reset?
bAsebAll1332 is offline   Reply With Quote
Old 07-15-2015, 11:09 AM   #12
08Mustang's Avatar
I'm not familiar with doing that or frankly what it is so I'm not sure but I do unplugging the battery will help
Old 07-18-2015, 09:40 AM   #13
rkaralash's Avatar
Yeah they both have the same affect. The tuner is more convenient and will save you the 30 minutes it takes to clear the KAM by unplugging the battery.
Also, I've seen some threads about pulling fuse 47? Anyone have any insight on the adaptive shifting and if it's on the 4.0's?
rkaralash is offline   Reply With Quote
Old 07-18-2015, 09:44 AM   #14
rkaralash's Avatar
Forgot to mention...
It's always good to do the idle relearn when clearing the KAM.
Sent from my SM-G920V using Mustang Evolution mobile app
Old 07-19-2015, 11:30 AM   #15
jek57's Avatar
Almost sounds like the transmission not going into gear .Does it like slam into gear when you give it gas ?
jek57 is offline   Reply With Quote
Lag in Acceleration/Throttle Response extreme963 2005-2010 Mustang GT 50 10-17-2016 03:18 PM
Lagging throttle response/chugging at 2,000 rpms Jfckr Pre-2005 V6 Mustang 7 05-31-2010 11:09 AM
Throttle response 05STANG Pre-2005 V6 Mustang 6 10-29-2006 08:30 AM
terrible, terrible news. DropTop_Stang The Bar 12 10-18-2003 09:01 PM
08:33 AM
