2006 GT Powerstop Brake Problems - Mustang Evolution
Old 06-27-2015, 09:45 PM   #1
Good evening guys, I just today installed new rear Rotors and pads on my 2006 GT.
I used Powerstop drilled and slotted rotors and their evolution ceramic pads.
I rented the special tool from AutoZone for the caliper piston and turned it until it would not turn anymore so I am 99% sure it is fully retracted.
The car feels like it decelerates faster than normal when I let off the gas or is under resistance from the brakes like they may be dragging.
I am getting a burning smell from the pads, but I read on powerstop's website that is
very common and is just the coating on the pads during "break in".
There is a decent amount of heat coming from the rear brakes as well.
What would be causing this resistance/dragging? The rotors? Or the pads?
I do not want to screw up the car or roast the brake components. I have ready many conflicting things about Powerstop and have seen some others with similar issues but no fixes as of yet.
NOTE: I just realized I put this under the V6 category, if a moderator could move it to the appropriate category I would appreciate it!
Thanks!
thellamattina is offline   Reply With Quote
Old 06-28-2015, 12:37 AM   #2
natestang07's Avatar
Your piston could be stuck. Is it on both sides or one?
Old 06-28-2015, 07:50 AM   #3
The driver's side is giving off more heat than the passenger side. So It could be the driver's side.
How do I test the theory of the piston being stuck?
And what is the fix for that? A whole new caliper?
And it has never done this before I just changed the pads and rotors.
Thanks
Old 06-28-2015, 08:21 AM   #4
Jon3.7's Avatar
Sometimes, they go bad whenever you depress the piston back in. Did you do the break in procedure?!
And yes, way to fix a sticking caliber is buying a new one
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-28-2015, 08:23 AM   #5
do I have to bleed the system if I replace just one caliper?
any other ideas of what could be causing this problem other than the caliper, before I just replace it?
Old 06-28-2015, 08:24 AM   #6
Jon3.7's Avatar
yes.
Old 06-28-2015, 08:33 AM   #7
is there a write up and procedure for caliper replacement and bleeding?
Old 06-28-2015, 08:35 AM   #8
Jon3.7's Avatar
You'll need a partner to help
1, remove the caliper, if possible, pinch the hose going to caliper to prevent air getting entirely into the system.
2 replace caliper, and hose
3. pump up brakes, check fluid level, then have a partner pump and hold brakes as you open, then you close and they pump and hold again
Old 06-28-2015, 10:42 AM   #9
Is there ANYTHING else it could be before I go replacing the caliper?
Old 06-28-2015, 11:15 AM   #10
Fabman's Avatar
Jack up the rear of the car and put it it in neutral.
Turn the rear wheels one at a time by hand.
If anything is dragging you'll know right away.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 06-28-2015, 11:17 AM   #11
The power stop brake pads are notorious for sucking.
Old 06-28-2015, 11:27 AM   #12
Fabman, thank you for the suggestion I will definitely try this.
Soccerluvr4, I have read mixed reviews about the pads some say their amazing and love them and others not so much. either way I do not think it depends on what is causing the problem.
Old 06-28-2015, 11:31 AM   #13
Fabman's Avatar
Tuned by AED
Old 06-28-2015, 12:56 PM   #14
I spun the wheel by hand and I do feel a VERY faint dragging. Should I hear absolutely no dragging? Or is a small amount normal?
I also realized that the nub on the back of the pad was not aligned with the hole on the piston. Could this cause drag?
Old 06-28-2015, 01:18 PM   #15
Fabman's Avatar
Line it up and let it go...you're fine.
Tuned by AED
Get $70 Off Powerstop Brake Kits At AmericanMuscle! AMAlexLazarus AmericanMuscle 0 10-13-2014 01:16 PM
Are powerstop rotors any good? 94gtconvert 1979-1995 Mustang GT 38 06-11-2014 09:47 PM
Powerstop Brake Rotor & Pads AJcruz1 2011-2014 V6 Mustang 17 04-06-2014 10:01 PM
Powerstop Brakes dshaley77 General Mustang Discussion 14 12-18-2010 10:45 AM
Which should I buy? A 2006 Nissan Altima SL? Or a 2006 Ford Mustang v6? sutton General Car Discussion 3 03-01-2010 09:57 AM
11:35 AM
