Fuel - Mustang Evolution
Old 07-12-2015, 06:24 PM   #1
mob86kl's Avatar
Fuel
I have a 2010 V6 4.0 L
What type of gasoline should I use regular or plus which is better for the stangs???
mob86kl is offline   Reply With Quote
Old 07-12-2015, 06:59 PM   #2
Bschmidty's Avatar
Regular will be fine. The only time a higher octane is typically run is if your car is tuned for it.
Bschmidty is offline   Reply With Quote
Old 07-13-2015, 06:54 AM   #3
08Mustang's Avatar
Yeah typically the 4.0 isn't gona see any noticeable benefit from running a higher octane unless you have your car tuned for it.
08Mustang is offline   Reply With Quote
Old 07-13-2015, 07:59 PM   #4
mob86kl's Avatar
Okay thanks ...
Old 07-16-2015, 07:35 AM   #5
Grabber10's Avatar
Running a higher octane is better for the car but you will not notice it without a tune because your computer is only looking to see regular 87
Sent from my iPhone using Mustang Evolutio
Grabber10 is offline   Reply With Quote
Old 07-24-2015, 07:40 PM   #6
05MUSTANG4.0L's Avatar
What mpg are you getting
Sent from my SM-G925T using Mustang Evolution mobile app
05MUSTANG4.0L is offline   Reply With Quote
Old 07-24-2015, 09:32 PM   #7
Grabber10's Avatar
Well guess it depends lol I have a good list of upgrades that pulls my mpg down, but when I rag on it 18-20 and when I'm cruise I can get anything from 23-28 but that's all highway and cruise control on
Old 07-27-2015, 10:44 AM   #8
JokerS197's Avatar
With the modifications I have on my 06, I actually over 30mpg on the highway. Last long distance trip I did I came up with 31 miles to the gallon average on the highway.
JokerS197 is offline   Reply With Quote
Old 07-27-2015, 05:41 PM   #9
TTmustang10's Avatar
How do you guys get over 20 im on a street tune and get 16.5mpg
TTmustang10 is offline   Reply With Quote
Old 07-27-2015, 05:49 PM   #10
Grabber10's Avatar
What mods are you running and who's tune?
Old 07-27-2015, 06:34 PM   #11
JokerS197's Avatar
I use the race tune that's why, 93 octane. Really I only have simple mods. BBK CAI, BBK 70mm tb, aluminum single piece drive shaft, pypes true dual exhaust, bama 93 octane race tune. I believe the Eiboch lowering kit helps with the cars cursing, the car rolls down the hill fast now then with stock suspension. Occasional I put royal purple engine cleaner in the tank to help clean the system out. I use nothing but full synthetic oil in my girl.
The convertible mustang weight is heavier the the hardtop, if I had the hardtop I could probably get even better mileage being that it's lighter. Again this is cruising on the highway. In the city it sucks on gas because of the stop and go, the race tune being aggressive. I wouldn't say my mileage is worse than stock in the city, but I could be better!
I wanted to install one of those under pulls belt system, they say it can increase fuel by a few more gallons. My goal is to make the most fuel efficiency out of my mustang with these gas prices change. I can swear that my gas gauge isn't broken! This recent test isn't the first, the key is to just use only cruise control.
Old 07-27-2015, 08:12 PM   #12
JimC's Avatar
Running higher octane than you are tuned for is not "better" for the car. It doesn't run any cleaner, give you better mpg, or any of the urban legends. In fact, it may be dirtier if you aren't tuned for it since you won't get a clean burn when you ignite because it burns slower. If your 2005-10 is tuned for higher octane then run it, if you aren't tuned for it then run 87 which is the stock tune.
On the 2011+ the story is different. They have knock sensors and will adjust timing until detecting knock and then back off. There is a small bump in power with them, but not enough that you would really notice (really, will your butt-dyno be able to tell the 10 hp difference?).
JimC is offline   Reply With Quote
Old 07-27-2015, 08:38 PM   #13
Texas22's Avatar
+1
Texas22 is offline   Reply With Quote
Old 07-28-2015, 06:28 AM   #14
08Mustang's Avatar
Well usually though the 93 gasolines have the premium cleaning agents in them though, more so than regular so it might run cleaner from that but not from the higher octane no. You're right it burns slower and colder than lower octane
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
should i have to change fuel.pump and fuel filter?? jmpark527 2005-2010 Mustang GT 11 11-11-2011 09:38 AM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
02:55 PM
