Lower - Mustang Evolution
Old 08-16-2015, 11:14 PM   #1
smazen24's Avatar
Lower
I wanna get eibach sportlines whay else would I NEED to do safely and nicely
smazen24 is offline   Reply With Quote
Old 08-17-2015, 07:54 AM   #2
Adjustable panhard bar and new shocks/struts/strut mounts at a minimum. For the strut mounts, I'd go with CC plates. With that big of a drop in the rear possibly an adjustable UCA & bracket to correct your pinion angle. Probably will want LCA relo brackets and if you're going through the trouble of adding those... mind as well get a set of LCAs.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 08-17-2015, 07:58 AM   #3
2 Stangz's Avatar
Region: Nevada
I'd go with a bumpsteer kit and ball joints too ^ Really helps on lowered cars and gets roll center back to optimal.
Old 08-17-2015, 08:10 AM   #4
tj@steeda's Avatar
It depends on your budget ... if you can do springs, shocks/struts, HD mounts & panhard bar all at the same time ... it would be ideal. The shocks & springs require the same labor so doing them at the same time will save you some $$.
Also, the stock mounts are not ideal for use with aftermarket springs & shocks.
If you would like, I can put a package together for you - the only issue is, we sell the Steeda springs ... which are a great compliment to the Steeda package.
You can email me at tim@steeda.com to discuss off forum if you wish!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
For Sale: 11-14 Oem lower Grille and roush lower Grille BoostedStang Mustang Parts for Sale and Wanted 8 08-18-2015 10:44 AM
To lower or not to lower .... SNK3BTE04 SVT Mustang 2 03-13-2012 08:46 PM
Can someone lower my car for me Zim The Bar 3 09-23-2003 05:12 PM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 03:43 PM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 10:37 AM
04:38 PM
