Can I squeeze anymore horsepower out? - Mustang Evolution
Old 09-01-2015, 05:51 PM   #1
slowstang08's Avatar
I have a basically full bolt on 4.0 minus the headers and I wanted to know if I could do anything inside the engine to increase hp? Could I port and polish anything that would help?
slowstang08 is offline   Reply With Quote
Old 09-01-2015, 06:12 PM   #2
parkerz28's Avatar
Boost the hell out of it 😜
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 09-01-2015, 06:14 PM   #3
Kevin.Cook
Guest
Posts: n/a
A port and polish along with a dialed in tune to take advantage of it, could net a few ponies.
Old 09-02-2015, 07:02 PM   #4
Any videos on that or how can I do it?
Old 09-02-2015, 07:04 PM   #5
Kevin.Cook
Guest
Posts: n/a
Have you ever done any porting before?
Old 09-03-2015, 03:50 AM   #6
Nope
Old 09-03-2015, 05:29 AM   #7
Kevin.Cook
Guest
Posts: n/a
Then i would not attempt it yourself. All it takes is 1 mess up to wreck your intake manifold. Best to find a shop that does it.
Old 09-05-2015, 10:49 PM   #8
superdrift's Avatar
Add longtubes and do the polish thing
superdrift is offline   Reply With Quote
Old 09-08-2015, 07:54 PM   #9
What do I polish and port exactly, my throttle body is already replaced with a BBK 70mm
Old 09-08-2015, 08:34 PM   #10
superdrift's Avatar
Upper and lower intake manifolds
Old 09-14-2015, 05:20 PM   #11
TTmustang10's Avatar
Aluminum drive shaft 8.8 rear w/ 3.73
Under drive pulley
Nitrous 400 shot would be nice nothing major
Full exhaust X or H pipe with long tubes.
Better pan hard bar and shocks, sway bar to plant the power.
A good tune
Cam grind
TTmustang10 is offline   Reply With Quote
Old 09-14-2015, 05:41 PM   #12
Old 09-14-2015, 05:43 PM   #13
Rapinator126's Avatar
Most of the ◻️ on this site aren't about that nitrous life.
🍼and 🌽 fed coyote.
Old 09-14-2015, 06:05 PM   #14
🍼and 🌽 fed coyote.
Anyone can build hpower with nitrous,have to have a little knowledge to make with just motor upgrades, reason lots of streeters go nitrous less money and knowledge needed
ALLYDRIVER1 is offline   Reply With Quote
Old 09-14-2015, 06:08 PM   #15
Not quite hot shot. A legit nitrous system is going to cost upwards of $5,500 easily. But keep flapping your mouth.
Might want to do some research b4 you decide to speak
🍼and 🌽 fed coyote.
Old 09-15-2015, 10:54 PM   #16
Augustlaydead's Avatar
Upgrade both your exhausts and air intake , that will boost your HP up by at least 15 at a low level upgrade and more if you get better quality stuff as well. The more she breathes the better she runs and puts out
Augustlaydead is offline   Reply With Quote
Ways to squeeze all the hp out of n/a 4v? 98GTCONV 1996-2004 Mustang GT 21 10-30-2013 08:45 PM
I have a 1988 Mustang that is putting out about 400 horsepower. Can I use a dual-disk clutch in it? jeffery 1979-1995 Mustang GT 2 12-21-2011 01:05 AM
My horsepower is faster than your horsepower Lalayla The Bar 24 03-17-2011 09:12 PM
Microsoft not number 1 anymore?? Brent The Bar 1 02-28-2004 02:41 PM
I can't do it anymore. Dom The Bar 23 01-22-2004 07:44 PM
04:24 PM
