HELP!!!! 2006 mustang v6 - Mustang Evolution
Old 09-20-2015, 04:14 PM   #1
I have a 2006 mustang that starts when it wants to. When i turn the key you'll hear the fuel pump turn on. That's how i know it's gonna start. If i don't hear it it's not turning on. Today while i was drivinging it it turned off on me, and had to get towed to my house then it turned on. What could it be? A relay?
Fontana raised is offline   Reply With Quote
Old 09-20-2015, 11:18 PM   #2
JokerS197's Avatar
Probably has to do with the fuel pump then, that's my best guess. If it shuts off while driving it could be because of the fuel filter needs to be replaced.
JokerS197 is offline   Reply With Quote
Old 09-20-2015, 11:45 PM   #3
The problem started about a month ago. All of a sudden it wouldn't start. Replaced the starter. After that it was running really ruff. I would start it and it with die sometimes it would start right back up and sometimes would have to wait about 20 minutes or longer for it to start. Then i clean the hose that goes to the carberater and the carberater it self. Under neath really dirty. Ran perfect for about a week. Then the other night went to dinner and it wouldn't start for a half an hour. Today went to the store while i was turning at a intersection it just died completely it i pushed it to the gas station called AAA had it towed to my house. As soon as the tow truck left i go to see if it will start it started. When i know it's gonna start you'll hear the fuel pump turn on if i don't hear it it's not gonna start.
Old 09-21-2015, 07:13 PM   #4
JokerS197's Avatar
I assume your taking about the throttle, no carbs on a fuel injection. Probably need a engine tune up, plugs, wires, coil pack. Buy some fuel system cleaners, like seafoam. Could be problems with the fuel pump wiring.
Old 09-21-2015, 07:23 PM   #5
ragtopman's Avatar
Prob need a new fuel pump...
ragtopman is offline   Reply With Quote
Old 09-21-2015, 08:32 PM   #6
Need more info codes maybe.shoulf be some
ALLYDRIVER1 is offline   Reply With Quote
Old 09-22-2015, 12:44 PM   #7
Electrical issues can plague you intermittently. Especially the ground wire connections. No use in trouble shooting until electrical connections are checked/cleaned up.
Old 10-06-2015, 06:19 PM   #8
mob86kl's Avatar
http://youtu.be/pXruFDl9wyc
mob86kl is offline   Reply With Quote
Old 10-06-2015, 06:21 PM   #9
mob86kl's Avatar
If you cant hear the audio
Go to youTube.com search for
2010 Mustang lose power
---------- Post added at 11:21 PM ---------- Previous post was at 11:21 PM ----------
I hope this helps you out I was going crazy when I had that problem
2006 mustang
Which car should I get? A 2006 Corolla S, 2006 Mazda 3i Sedan, or a 2005 Lancer Es? brant General Car Discussion 5 07-19-2011 05:23 AM
mustang gt :: 2006 Ford mustang gt premium wereKEV Member Garages 0 06-15-2011 01:01 PM
Torch Red Mustang :: 2006 Ford Mustang GrabberBlue10MJ Member Garages 0 06-15-2011 01:01 PM
mustang GT :: 2006 Ford Mustang GT hottcobra Member Garages 0 06-15-2011 01:01 PM
Which should I buy? A 2006 Nissan Altima SL? Or a 2006 Ford Mustang v6? sutton General Car Discussion 3 03-01-2010 10:57 AM
09:31 AM
