2010 Auto V6 Backend Knock - Mustang Evolution
Old 10-26-2015, 09:03 PM   #1
So I have searched high and low through the forums and haven't seen anyone bring up the issue yet. I have a 2010 4.0, very lightly modded and recently have run into an issue with the car rev'ing high to clear 2nd gear then a knock from the back end when it goes into gear. Recently (1 week prior) treated the car with "Lucas upper cylinder lubricant". The issue lasted a full day and maintenance light was visible, got back in the car the next day and the issue resolved itself. Beyond a few spirited street pulls I drive the vehicle without putting much wear or stress on the engine. Anyone have a clue what this may have been?
*was advised to turn off o/d and traction* issue resolved before these measures were taken.*
Sent from my SM-N915T using Mustang Evolution mobile app
GrigsVI is offline   Reply With Quote
Old 11-03-2015, 07:37 AM   #2
did you find out what exactly was causing the problem?
martinez8191 is offline   Reply With Quote
Old 11-03-2015, 07:57 AM   #3
Kevin.Cook
Guest
Posts: n/a
So you are shifting at a high RPM when changing gears AND then you hear the sound? Have you checked your driveshaft for play? How many miles do you have? Have you checked your differential and trans fluids?
Old 11-04-2015, 11:18 PM   #4
The car is going into higher RPM before changing gears, and after the transmission goes into gear the sound occurs. Haven't checked for any play in the driveshaft. But I did read where the the lucas lubricant could cause certain fittings to swell and crack causing different issues. The milage is right around 55,000 and the trans fluid on the 2010 v6 is capped and cannot be checked conventionally. Problem somewhat resolved itself I've been driving cautiously and have only had it occur once since the first instance. Trying to get to Ford for them to take a look but work has been keeping me busy.
Old 11-05-2015, 06:12 AM   #5
Kevin.Cook
Guest
Posts: n/a
Wait, so when you say backend, are you referring to the backend of the engine bay area or of the entire car itself?
Old 11-05-2015, 06:30 AM   #6
Backend of the car itself, almost sounds like something is slamming in the trunk.
Old 11-05-2015, 06:35 AM   #7
Kevin.Cook
Guest
Posts: n/a
Have you tried having a friend drive next to you so they can try to hear it? Or have someone drive your car and you drive next to it in another car?
Down force for the backend WarriorStang 2011-2014 Mustang GT 9 04-16-2014 07:53 AM
SCT tuner and knock and pinging ajpturbo 1996-2004 Mustang GT 10 09-13-2010 07:17 AM
Knock Knock *Language* Brent Pictures and Videos 3 04-03-2008 04:18 PM
Some kind of knock Ibanezplayer272 Pre-2005 V6 Mustang 19 02-02-2007 10:50 PM
95 Mustang GT engine knock 95 GT 1979-1995 Mustang GT 7 09-12-2006 06:30 PM
03:03 AM
