Super stiff struts - Mustang Evolution
Old 10-27-2015, 08:41 AM   #1
Jar72's Avatar
Super stiff struts
06 GT, stock suspension,rims and tires ( size) has 77k on it. Noticed excess tire wear inner tires ( more on Driver side) Toe in was only about 1/16th" off. Caster camber is off. slightly, assumption is just normal settling. But my front is super stiff. Father in law ( used to own alignment shop, good mech had a couple strokes)
said the struts are collapsed. I argued it a little about if they did then the car would ride like a bouncy ball. He swears the struts are collapsed. SOOO if you push down on the front its stiff, it takes alot to get her to sink. but its really tight on corners, no body roll or sway at all. ( 75 mph full circle onramp stays flat ). it does ride a bit rough but thats not an issue for me. SOOO in order to set the wife at ease, anyone that has any experience or advice for or against let it rip.
JMF
Jar72 is offline   Reply With Quote
Old 10-27-2015, 08:46 AM   #2
Kevin.Cook
Guest
Posts: n/a
Do you hear clunking in the front when going over bumps? 50-60k miles is the target for replacing stock struts. Sometimes you can get a little more out of them. But around 50k is when I do mine.
Old 10-27-2015, 08:57 AM   #3
Jar72's Avatar
no noises I have a floor board bump but thats from an exhaust bolt i need to move as for the struts you hear that gas sound.
JMF
Old 10-27-2015, 08:59 AM   #4
Kevin.Cook
Guest
Posts: n/a
Well since you are starting to get outside the recommended maintenance interval for replacing that, all I can suggest is taking it someplace for a 2nd opinion. As these things are hard to diagnose remotely. Since we cannot physically see/inspect everything.
Old 10-27-2015, 02:31 PM   #5
I had this happen with a shock absorber once. I suspect that the "valving" inside of the shock somehow failed, and it became extremely stiff. So much so, that it was very difficult to compress it enough to remove it!
This is probably the problem with your struts.
Old 10-28-2015, 07:35 AM   #6
Jar72's Avatar
Now that makes sense and considering it was shipped from AZ CA border to south Ga when we moved in June, the car was cranked down on an auto transport for over a week, i will be using a jack tonight to lift it and see if they open and or compress at all. thanks Stray bullit.
JMF
Old 11-01-2015, 04:30 PM   #7
Jar72's Avatar
Well the ride has softened up. Come to find out my front tires started to separate on the inside. Still should do struts but now she's smooth again. As for the noise inner plastic fender well had loosened up and was moving around.
JMF
Stiff gear shift. Small or big problem?? ecash General Mustang Discussion 0 03-17-2009 03:48 PM
Notchy MGW Shifter and Super Stiff King Cobra Clutch Cajun JungleBoy 1979-1995 Mustang GT 14 06-11-2008 02:09 PM
stiff shifting after 3200rpms? tedness Pre-2005 V6 Mustang 9 03-19-2005 11:21 AM
Dont you hate it when people say they will pay for something and stiff you...(inside) SpectorV The Bar 28 10-05-2004 12:07 AM
grinding sound, stiff breaks, and loos of power wile driving blk2kconvstang Pre-2005 V6 Mustang 4 04-05-2004 07:20 AM
09:22 AM
