Sucking Sound - Mustang Evolution
Old 10-31-2015, 05:49 PM   #1
JokerS197's Avatar
Sucking Sound
So recently I put a new set of spark plugs in my engine. Now every time I put the car in drive or reverse you hear a thumping suction noise. What it sounds like to me is its coming from a cylinder. The noise sounds like it's suction from a piston. This is because you hear the sound for a short moment like it's combusting and gets quiet and then you hear the sucking again. It's only coming from the right side of the engine (passenger side). I check the gapping on the spark plugs and it seems to always be gapped correctly. No check engine light has come on, I don't know if that's because of the engine tune. I'm assuming if the engine still had a problem, the check engine light would still come on regardless if it has an engine tune or not. Does anybody know what the problem is?
JokerS197 is offline   Reply With Quote
Old 10-31-2015, 06:30 PM   #2
your girl friend maybe?
ALLYDRIVER1 is offline   Reply With Quote
Old 11-01-2015, 08:54 AM   #3
dave73's Avatar
Sucking Sound
Are you sure it's a thumping and sucking sound? 🤔
dave73 is offline   Reply With Quote
Old 11-03-2015, 07:41 AM   #4
I read about someone installing new spark plugs and later getting a thump noise in the back. Was just part of the plugs. Went away after a while. any updatE?
martinez8191 is offline   Reply With Quote
Old 11-03-2015, 07:48 AM   #5
JokerS197's Avatar
Unfortunately the sound is still there. I am planning on replacing the distributor wires today, maybe I damaged the power cord so it's not getting full combustion? I took it into ford and they couldn't understand what is wrong. The only thing they could do was use a compression tool to check the cylinders. It's $150 to have them tested. So I am waiting to see if changing the wires will help. If not I will probably have it tested. I don't seem to notice a lack of performance, it just doesn't sound normal.
Old 11-03-2015, 05:05 PM   #6
dave73's Avatar
First of all what year Mustang are you talking about?
Old 11-03-2015, 05:40 PM   #7
JokerS197's Avatar
2006
Air sucking noise RobbyD 2011-2014 V6 Mustang 8 07-25-2013 08:00 AM
Magnaflows sucking my gas NicholasP 2011-2014 V6 Mustang 11 05-03-2013 04:39 AM
sucking in air? b.hewy94 1979-1995 Mustang GT 5 02-16-2013 01:04 PM
Popping sucking sound help! austinknoll Pre-2005 V6 Mustang 24 01-05-2013 10:36 PM
I have a v8 1977 mach 1 mustang whats the reason for it sucking up so much gas than a normal v8? iddig17 Classic Mustangs 2 12-18-2011 04:50 AM
01:58 AM
