Coolant smell - Mustang Evolution
Old 01-05-2016, 08:48 AM   #1
Blackstang08's Avatar
Coolant smell
Hey whats up guys? Question for y'all I recently replaced my thermostat housing yesterday. And a lot of coolant ended up coming up due to some pieces not working properly. Now my question to you guys is this should I still be smelling coolant when I stop or when I'm parked but can't find a leak no any lost in coolant?
Blackstang08 is offline   Reply With Quote
Old 01-05-2016, 09:44 AM   #2
bucko's Avatar
Depends on how much coolant leaked. Likely it puddled up in some of the engine areas, and when the engine gets warm, it's burning/evaporating off. Give it another day or two to burn off.
Check the coolant overflow tank to make sure it's staying at its proper fill level, indicating that there is no more leakage.
Old 01-05-2016, 09:57 AM   #3
Strange Mud's Avatar
you may want to clean the engine to eliminate any spilled on. Keep an eye on the level if it stays up it ain't leaking and the smell should go away in a few days. It's a good excuse for a road trip to burn it off!
Old 01-05-2016, 10:29 AM   #4
When you have a coolant leak that gets everywhere you'll smell it for weeks afterwards sometimes, even after you fix the issue.
Old 01-05-2016, 05:22 PM   #5
Diehard's Avatar
As you know coolant level fluctuates with temperature of the engine. So be sure you are comparing levels when at similar temperatures, when trying to determine if there are any leaks.
Of course after initial fill you can expect level to drop a bit.
Old 01-05-2016, 05:51 PM   #6
Hey guys I've been looking over it as of yesterday and haven't seen any major coolant drop in the tank it dropped a little the first day then has been levels at the same place since then.
Old 01-09-2016, 12:44 AM   #7
Well the level definitely went down under the line but seems to be steady
Old 01-09-2016, 12:47 AM   #8
Well the level definitely went down under the line but seems to be steady but somehow still have a smell going on
Transmission Fluid Smell Rainman64 1979-1995 Mustang GT 3 07-25-2009 09:08 PM
Clutch smell issue Rich_Guy 1996-2004 Mustang GT 7 07-14-2009 09:56 PM
Gas leak/Smell? runvsofthisbull Pre-2005 V6 Mustang 15 12-27-2008 04:58 PM
Whats that Smell? Kyle The Bar 6 07-12-2005 04:25 PM
Antifreeze smell? steedav6builder Pre-2005 V6 Mustang 6 07-15-2004 10:30 PM
06:21 PM
