Next upgrade? - Mustang Evolution
Old 06-19-2016, 01:41 PM   #1
Next upgrade?
I'm not sure what my next upgrade on my 2008 v6 should be. I have a BBK CAI, 70mm throttle body, pipes true dual system with M80s and 93 octane racing tune. I was thinking either a suspension kit or differential with 4.10 gears. Any suggestions?
stangduded1983 is offline   Reply With Quote
Old 06-19-2016, 04:13 PM   #2
Suspension.
Old 06-20-2016, 05:11 PM   #3
Thanks, does it really make that big of difference in the ride?
Old 06-24-2016, 09:06 AM   #4
FastFord13's Avatar
What gears are you currently running?
Sent from my SM-G925W8 using Mustang Evolution mobile app
Old 06-24-2016, 11:17 AM   #5
Just the stock gears.
Old 06-24-2016, 02:56 PM   #6
FastFord13's Avatar
Those are 3.31s? I would do gears, 3.73s.
Old 06-24-2016, 05:54 PM   #7
Its an automatic, i had to look it up it has 3.31 gears. Any reason not to go with the 4.10 gears? I hear their pretty awesome.
Old 06-27-2016, 05:06 PM   #8
45thMustang's Avatar
With your auto transmission i would get the tci ratchet shifter. Installed one on my old 2009 mustang and its the most fun you can have in an auto. Looks good in my opinion and was an easy install for a lot of fun. Probably my favorite mod that I did to the car besides ditching the hideous stock wheels.
Sent from my SAMSUNG-SGH-I257 using Mustang Evolution mobile app
45thMustang is offline   Reply With Quote
Old 06-27-2016, 08:17 PM   #9
Kinda expensive for a shifter, about 500 bucks. I kinda played around with shifting 1st -3rd gears. Looks cool though.
Old 06-27-2016, 09:42 PM   #10
I put mine in when the stock shifters indicator light broke. Totally worth it in the end but not for everyone i guess. Its better being able to use the first three gears since you just bump it up instead of pressing the button in before switching gears like on the stock. Its kind of like having a four speed since you can bump from 1-3 and then straight into drive right after. But between your two suggestions its a tough call. Suspension is where the 4.0 would be best off since its not too fast in a straight line and its nice to be able to corner fast but then again having a posi rear end is also a plus so you can have the power at both wheels. Id pick differential and gears if it were up to me. Best of luck with the modding!
Old 06-27-2016, 09:47 PM   #11
Hey, thanks. Yeah that's probably the route I'm gonna take with the gears then suspension later on. I'll probably call Ford later this week to see how much it would cost to install posi with gears and shop around.
Old 07-07-2016, 03:43 AM   #12
Well, looks like I'm doing suspension I got a really good deal on the Eibach sport kit with shocks and springs. I will install at the end of the month when I have time. I'll be sure to post some pics.
Old 07-07-2016, 08:05 AM   #13
Can't go wrong doing suspension and more than likely not long down the road you'll be able to gear her!
Slow Grabber Blue 3V
Old 08-11-2016, 02:57 PM   #14
So just lowered the mustang and got the alignment. Night and day difference in handling. Its great!!! Here's a couple of pics and a before and after.
ID:	204127   Click image for larger version
ID:	204129   Click image for larger version
Old 08-11-2016, 04:32 PM   #15
FastFord13's Avatar
Big difference! How much did you drop?
Old 08-11-2016, 05:02 PM   #16
2 inches in the rear 1.6 in the front. I really didn't measure before I suspect its a bit more. There's only like 6 inches clearance between the front part of the k member and the ground. I've found that I'm gonna need a new floor jack.lol I didn't need any camber plates or anything. They got it within a couple degrees of spec with a little negative camber. Corners like a beast!!!!
Old 08-15-2016, 12:48 AM   #17
KATO's Avatar
4.10's are awesome, but they have a Down side also. The 373's may be a nicer choice. 4.10's are Way Faster, Blinding Faster, but the two downsides are kinda big, You will get to point b (a to b) quicker than anybody but you'll loose your Top End Speeds, they wont get up to those speeds again. And the Higher Revs will lessen your gas miles. If your stock car gets to 130mph, after gears you won't get anywhere near there again.
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R MORE LISTED INSIDE.
Old 08-15-2016, 02:48 AM   #18
Can you feel the difference with 373's?
Old 08-18-2016, 01:04 AM   #19
KATO's Avatar
You should feel an instant difference. Remember a lot of Performance cars come from Dealership with 373's.
Old 08-31-2016, 12:59 AM   #20
alecas447's Avatar
On a v6?
Mac o/r H pipe. Flow master super 44s. Accufab 75mm throttle body. Pro comp intake manifold. MSD coils. MGW short throw shifter, exedy stage 2 clutch
alecas447 is offline   Reply With Quote
Old 08-31-2016, 09:27 AM   #21
KATO's Avatar
That specific detail, I don't know.
Old 08-31-2016, 03:06 PM   #22
I know only what reviews I've read on american muscle. Most like the 3.73s; there were a few comment of remorse of not going with 4.10s. I might just stop and work on the cosmetic issues my rides has. I have clear coat peeling in areas.
Old 08-31-2016, 03:07 PM   #23
FastFord13's Avatar
You do feel an instant difference! Going from 2.73 to 3.73s is night and day! Best mod I've done and it should have been my first.
Samsung Galaxy S6 Edge.
Old 09-02-2016, 06:28 PM   #24
If you don't mind me asking how much was labor to install?
Old 09-02-2016, 08:13 PM   #25
FastFord13's Avatar
I paid $650 Cad which included everything, Ford racing 3.73s, Royal Purple labour and taxes.
Old 09-02-2016, 08:34 PM   #26
Originally I was thinking about this kit but you guys got me rethinking the 4.11 gears. That's not a bad price for everything.
Old 09-08-2016, 01:08 PM   #27
TrevorMCA's Avatar
I have the 4.10 gears and I love them. I don't do a lot of high way driving and that's where people complain. On the highway my rpms stay around 2400 and some people don't like it. I personally do and when I drive highway I get around 26mpg. 4.10s are extremely fun and you'll beat anyone off the line. Idk what my top speed is because I still have the 2 piece driveshaft but I've gone 135. No problem. I spin switching into second gear with brand new nitto g2s. It's a lot of fun but 3.73 would be a great medium
2012 Kona Blue MCA Cyclone
AIRAID CAI
4.10 gears
Ford Racing Axle Backs
'Unknown Tune'
TrevorMCA is offline   Reply With Quote
Old 09-08-2016, 07:27 PM   #28
I drive 35 miles to work not sure what my top speed is. I have customer firmware on my phone and it doesn't like my wireless Bama tuner so I can't run the tests it has on it. I just need to find a shop or call ford to do this for me.
Old 09-09-2016, 05:50 PM   #29
Just got quoted 800 bucks for a gear swap at ford. That's just labor oil and seals, not parts. I guess I'll be shopping around.
Old 09-09-2016, 06:22 PM   #30
TrevorMCA's Avatar
Dang that's terrible. Yeah I would definitely shop around or find a mustang dude near you that knows what he's doing. The only good thing about the dealership, is they have to fix whatever they break in the process
AIRAID CAI
4.10 gears
'Unknown Tune'
Old 09-12-2016, 03:04 PM   #31
JokerS197's Avatar
You have to be careful with that suspension! The two biggest waste of money (in my opinion ) that I did to my 4.0 was the suspension and 70mm throttle body. Your aftermarket exhausted pipe with probably hit the ground when drive up slanted drive ins. Also towing becomes an issue. In order to get it on the flat bed you have to put bricks under the rear wheels. Same if you want to get it up on a ramp like a normal auto shop.
JokerS197 is offline   Reply With Quote
Old 09-12-2016, 03:31 PM   #32
I haven't had that problem but I've been pretty careful. I got a good deal on the eibach sport line kit not just springs it was 450 and I did the install myself. It handles like a dream and no body roll. Ive only scraped once it was just the rocker panel as far as i can tell. The throttle body was probably a waste but I paid like 90 bucks for it. I got lucky and found it in a close out on eBay it was SR performance though it was missing 2 bolt on screws.
Old 09-14-2016, 07:32 PM   #33
I found a shop in the area that would do it for 450 if I brought them the differential and the gears. Its still helps expensive with the parts but I think I'm gonna do it considering ford wanted 800 just to install. This will probably be my last upgrade other than cosmetics.
Old 09-18-2016, 03:21 AM   #34
Matts's Avatar
Heavy-duty radiator and fan to prevent overheating. Trust me, it sounds foolish now, but you'll wish you'd done it years ago.
Matts is offline   Reply With Quote
Old 10-08-2016, 01:39 PM   #35
Well, finally got my gears done it cost me 575 to get it done. I like the gears they're fast and the extra traction too is nice. I'll have to wait till next week for a tune to recalibrate the speedo. I was pretty sure itsx would let u change the ratio but can't find it anymore. Also ,I developed an issue I must a scraped somewhere and knocked the drive shaft outta alignment. It vibrates at high speeds I think around 85.
next upgrade kickerofdoom Pre-2005 V6 Mustang 6 05-25-2011 09:34 AM
The next upgrade... Blackedout Pre-2005 V6 Mustang 15 05-11-2011 05:35 PM
The next upgrade... Blackedout Pre-2005 V6 Mustang 6 04-06-2011 08:45 PM
Next upgrade question arlander344 1996-2004 Mustang GT 16 04-07-2010 11:37 AM
Next Upgrade?? 2kslvrgt 1996-2004 Mustang GT 6 02-07-2009 03:56 PM
03:42 PM
