Battery Light - Mustang Evolution
Old 06-28-2016, 04:33 PM   #1
Battery Light
Hey everyone, first time poster on this site so sorry if I don't know all the lingo. I have a 2005 V6 4.0L Mustang. First time Mustang owner and it is my first car. When I bought it I noticed it was going to be a lot of work and money to fix it up. One of the main problems I have noticed is the battery light turning on and off. It just randomly turns on and off, with that being said the car has never turned off on me (thank god) It used to pop up maybe once every two weeks. Now I am noticing it is popping up almost every time I drive it. The light pops up for about 2 minutes then disappears then does it again. I took it to Autozone and got the battery and alternator checked out, they both are fine. So I checked the fuse box and its still good. I have yet to check the ground cables which I will be doing soon. The thing I want to know is if there are anymore things I should check that could be causing this. Any help is appreciated, thanks guys.
Ramram563 is offline   Reply With Quote
Old 06-28-2016, 06:55 PM   #2
Diehard's Avatar
Were they able to test the alternator while the red light was on? Sometimes the built in voltage regulator fluctuates when it's on it's way out.
You should try to check the alternator output while the red light is on. If you don't already have one you should buy yourself a multimeter.
After checking cables for tightness, check alternator belt for looseness.
Old 06-29-2016, 10:01 AM   #3
Strange Mud's Avatar
Ram,
what DH said....check connections at alt & battery also check voltage at battery. Good luck and let us know what you find if we can we'll give you more things to try.
Welcome to Mevo
Mud
Old 06-29-2016, 10:03 AM   #4
tombrochard's Avatar
A loose connection on the charging post of the alternator will produce that condition
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 06-30-2016, 05:27 PM   #5
They weren't able to test it while the battery light was on. I think I have a multimeter lying around so I'll check that all out and let you know.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
Old 07-01-2016, 08:01 AM   #6
car off 12.6 volts
running 13.6-14.6
Old 07-03-2016, 09:00 AM   #7
jeno's Avatar
Originally Posted by Strange Mud View Post
car off 12.6 volts
running 13.6-14.6
Is that checking all wires to the alternator pigtail with the car on your suppose to have power to all wires not just one and that's not running just with the ignition in the on position
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-04-2016, 04:26 AM   #8
i was referring to battery. You would have to look at a schematic for the alt.
Oil light+Battery light= MAF Error... rebeltx 2011-2014 V6 Mustang 0 05-03-2013 02:43 PM
Battery Light megax29 Pre-2005 V6 Mustang 1 06-20-2007 03:11 PM
Battery light comes on under hard acceleration Brent Pre-2005 V6 Mustang 23 02-05-2005 03:18 PM
Battery Light fordfan1184 Pre-2005 V6 Mustang 2 08-27-2003 03:16 PM
08:12 AM
