mike 09 - Mustang Evolution
Old 07-31-2016, 05:33 PM   #1
mike 09
hello new to group , I have a brake light issue. tail lights all light up. inner two brake lights don't light up. has anyone know what the problem would be. mike
murphy is offline   Reply With Quote
Old 07-31-2016, 07:42 PM   #2
twk
twk's Avatar
How often do you check your lamps?
Maybe one burnt out, then the other, but you didn't notice until you lost them both. It's not very likely they both blew at the same time, but not impossible either.
twk is offline   Reply With Quote
Old 08-01-2016, 06:10 AM   #3
jkeaton's Avatar
Have you done the simple stuff yet? Check the bulbs for one....
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-01-2016, 07:14 AM   #4
JimC's Avatar
When you say "inner two brake lights" are you meaning when you step on the brakes they don't illuminate? But otherwise they are lit with the headlights switch?
If so, I believe that is normal and only the outer bulbs light with the brakes and turn signals
Sent from my SM-G930P using Tapatalk
JimC is offline   Reply With Quote
Old 08-01-2016, 07:21 AM   #5
mike 09
They're not supposed to light up when you hit the brakes. As Jim said, they light up when your headlight switch is on.
Old 08-01-2016, 06:03 PM   #6
murphy
hello everybody thanks for getting back. here is how this started. had the airbag replaced at the dealer on Saturday. you know how they come back you got this problem that one. that's when they said two brake light bulbs out . I said I will fix that. I replaced both bulbs same thing . with headlights on all lit up and when I press brake inner two don't go brighter. I thought this was a little strange. driving home today from work I saw another mustang and saw the brake lights are the the same as mine. after your replies I am assuming that this is normal. teck at dealer not up to speed on this one. lol thanks for your replies.
Old 08-01-2016, 09:02 PM   #7
Gravydog316's Avatar
Try swapping bulbs; turn the hazards on...
i have learned each car is different, even if they are the same year haha.
wiring issue, maybe?
Sent from my iPad using iOS X beta 2
Old 08-02-2016, 06:38 AM   #8
Junior Member
Region: Arkansas
Mine didn't light up until I put the sequential harness on my car.
notthead is offline   Reply With Quote
Old 08-02-2016, 12:02 PM   #9
twk
twk's Avatar
Since you already checked the lamps, I would pull the whole harness out and reinstall your original harness and see if the lamps start working again. Well, except for the inner most lamp.
Its a great day for Mike Zimmerman Zim The Bar 17 06-23-2005 10:48 AM
Some new(er) pics of my car..bringing the heat mike!! greenflash00 Mustang Audio & Video 18 06-24-2004 02:26 PM
Mike needed one of these Brent The Bar 11 06-20-2004 09:13 PM
Mike, Can this be..... 03redfire cobra The Bar 10 05-18-2004 11:13 PM
Everyone must read. **Mike Drunk** Brent The Bar 11 03-12-2004 12:39 PM
10:53 PM
