Convertible top motor not working - Mustang Evolution
Old 09-06-2016, 09:52 AM   #1
I have 2006 convertible, top will not go up, the switch work ok, windows go down, Fuse looks good, i can hear relays click ( I think its the relay). Any suggestions
seadog78 is offline   Reply With Quote
Old 09-06-2016, 11:36 AM   #2
jkeaton's Avatar
Check the fluid level, check for binding.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 09-06-2016, 09:00 PM   #3
Take the back seat out and look for leaks from the pump, lines or pistons that raise the roof. If you see red fluid anywhere you got a leak somewhere.
Matt E. is offline   Reply With Quote
Old 09-07-2016, 09:54 AM   #4
twk
twk's Avatar
Can you hear the motor humming like it's trying to run? Or completely quiet?
Any sound from motor with switch in Up or Down. There is a separate relay for up and down. Sorry, I dunno their designation or locations. Probably near the fuses.
2 fuses too. F51 for raise, F13 for lower. Huh, I didn't know that 'till just now.
twk is offline   Reply With Quote
Old 09-07-2016, 08:17 PM   #5
Convertible top not working
I just fixed this problem recently myself with my convertible. Go on you tube and look up videos on how to fix the motor of your top. You will have to take apart your back seat to fix the problem. My fluid was out in my motor. I filled up the pump like the video said and now my car is as good ad new. Works perfectly. Thank God for you tube. Saved me some money.
Glen75 is offline   Reply With Quote
convertible top not working doreena 1996-2004 Mustang GT 3 03-02-2015 04:09 PM
Convertible Top Motor/Pump Fluid Flush/Refill FYI POST runvsofthisbull 1996-2004 Mustang GT 0 06-23-2012 01:12 PM
I have a 1991 mustang convertible with a eighty's top what top to buy? ? Keme 1979-1995 Mustang GT 1 12-11-2011 11:52 PM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
Convertible Top Button Quit Working SuperDave2010 1996-2004 Mustang GT 3 07-06-2010 09:12 AM
01:48 AM
