Oil Filter issue - Mustang Evolution
Old 10-04-2016, 07:00 PM   #1
JokerS197's Avatar
Oil Filter issue
So I did an oil change recently on my 06. After driving it I noticed some leaking oil seeping down the oil filter. My first assumption was that I must have over tightened it. I did the same thing on my boss 302 when I change the oil, I had tightened it too tight and start to leak. So I figured it was a mistake and I got another oil filter to replaced it. Now I know seeing this filter starting to leak. I already checked to make sure there was no other rubber ring from the old filter. This filter I didn't tightened up too tight, just normal hand tight. Do you think the filter could be too loose?
JokerS197 is offline   Reply With Quote
Old 10-04-2016, 07:47 PM   #2
check to see if you left the old o ring on
Heinz
06 GT, auto, 65K
hfca is offline   Reply With Quote
Old 10-04-2016, 07:54 PM   #3
jkeaton's Avatar
Are you sure it's from the filter and not the housing?
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 10-04-2016, 07:57 PM   #4
JokerS197's Avatar
Yeah I pulled off the old ring, so it's not that. I am assuming it's just the filter. Only oil seems to be appearing around the filter. Never had this issue before. Maybe I should tighten it? On my Boss 302 I thought I over tightened it, maybe it's to loose.
Old 10-05-2016, 05:54 AM   #5
Strange Mud's Avatar
tighten it (hand tight + 1/4-1/2 turn)
Issue with hood vents and exposed intake filter Kevin.Cook 2011-2014 V6 Mustang 27 06-05-2015 10:36 AM
Best oil & oil filter xrsfx Pre-2005 V6 Mustang 5 05-18-2015 10:46 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 12:37 PM
Yes i asking this, how do you properly re-oil a filter? Jrw4482 1979-1995 Mustang GT 12 05-14-2006 06:47 PM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 06:37 PM
01:24 PM
