Starting problems - Mustang Evolution
Old 10-06-2016, 05:45 PM   #1
MustangmanV6's Avatar
Starting problems
So I have been having issues with starting my car. The car will turn over but it acts like there is not enough to keep it going initially and will drop rpms and **** off. Sometimes if I can catch it I can step on the gas pedal to keep the rpms up and keep it from strutting off. Any and all help is well appreciated.
MustangmanV6 is offline   Reply With Quote
Old 10-09-2016, 12:37 PM   #2
Could be many things. Battery, air flow sensor, tune, sounds like the sensor did you just recently add a cold air intake?
Sent from my 0PJA2 using Mustang Evolution mobile app
airforcegreen09 is offline   Reply With Quote
Old 10-09-2016, 01:23 PM   #3
So battery is new, I just also replaced the belt tensioner because that had some movement in it and sounded like it was grinding at higher rpms. CAI has been in for a long time, the tune maybe the cause I started to notice it more after it was updated now that I think of it.
Old 10-09-2016, 02:29 PM   #4
Could also be mass air flow sensor going bad unplug your battery pull your mass airflow sensor out and clean it out could be that
Old 10-09-2016, 03:52 PM   #5
JokerS197's Avatar
Change the plugs and wires lately?
JokerS197 is offline   Reply With Quote
Old 10-09-2016, 04:53 PM   #6
Thanks I'll give that a try.
Yes plugs and wires were replaced to recently
New owner, 2002 Mustang starting problems skelaw Pre-2005 V6 Mustang 6 02-22-2011 07:57 PM
Starting problems! 99 SVT Cobra 1996-2004 Mustang GT 2 01-10-2010 05:47 PM
1989 5.0 starting problems tellico40 1979-1995 Mustang GT 5 10-19-2006 06:21 PM
Starting Problems Zak Attack 1979-1995 Mustang GT 16 05-17-2006 08:54 PM
1998 Ford Mustang Starting Problems redv6stang Pre-2005 V6 Mustang 4 09-25-2005 03:17 PM
05:47 PM
