8.8 Rear End Really Needed? - Mustang Evolution
Old 10-10-2016, 01:59 PM   #1
I have an 05 V6 and I like to drive it rather spirited on the back roads and highways. I'm not a drag racer nor am I pushing out 400 to 500 horsepower to rear wheels, just the stock amount. So my question is; is an upgraded 8.8 rear end really needed for what I'm doing? The 7.5 can be upgraded to 3.55, 3.73, or greater gears. So would an 8.8 benefit someone like me at all?
benwhite911 is offline   Reply With Quote
Old 10-10-2016, 02:21 PM   #2
MustangmanV6's Avatar
From my understanding the 8.8 is a lot stronger and will give you the benefit of putting power to both wheels. Not sure if you don't plan any performance upgrades if it's really needed.
MustangmanV6 is offline   Reply With Quote
Old 10-10-2016, 02:30 PM   #3
Sorry, let me clarify the upgrades I've made so far. I do have a performance tune, cold air intake and axle back exhaust. I also plan on doing longtube headers soon as well. With everything currently, I not pushing out too much more than stock power to the rear.
Old 10-10-2016, 08:01 PM   #4
JimC's Avatar
All it took was a tune, CAI, and a set of drag radials to break my supposedly indestructible Richmond gears on my 2006. Then when I swapped to the 8.8 it was CHEAPER to swap the rear end than it was to put the 3.73 gears and tlok in the 7.5.
JimC is offline   Reply With Quote
Old 10-11-2016, 12:28 PM   #5
olerodder's Avatar
Region: Oregon
A stock 8.8 rearend is about 30% stronger than your stock 7.5 rearend.
Old 10-11-2016, 12:55 PM   #6
I am sure you only would need to do a swap to an 8.8 rear if you had plans to boost the 4.0L. Some say its cheaper to swap but, you would have find a take off for under $500 for that to be true.
CJZona is offline   Reply With Quote
Old 10-11-2016, 01:03 PM   #7
olerodder's Avatar
Region: Oregon
Not sure where you live although I think I'd scour Craigslist...
8.8 Rear w/ 4.30s and brakes
Would be kind of fun with the 4.30's...some 40 years ago I had a 289HiPo 4spd 1964 Comet Cyclone with 4:56's on the street and it was a real blast to pull 2 car hole shots on the GTO's and other wanted to be fast cars...IMHO
Old 10-11-2016, 01:35 PM   #8
JimC's Avatar
That won't work. You need a 2005-14 rear end. We use a 3 link attachment not the same size either
Old 11-20-2016, 05:41 PM   #9
no
Azizmug is offline   Reply With Quote
Old 02-04-2017, 09:23 PM   #10
4.0nativepower's Avatar
Region: Nevada
Agreed. I am just now going to change my gears out from stock 3.31 with 3.73 i had already bought 3.73 with 8.8 so how that works is truly depends on how much hp and tq you plan on reaching. I am trying to reach close to 500 hp so i am going with a turbo kit and boost no more then 12 psi which is safe to run with stock internals and stock rear 7.5 8.8 do handle alot more power it just depends on how much hp and tq you want to exceed.
4.0nativepower is offline   Reply With Quote
Old 02-04-2017, 10:44 PM   #11
olerodder's Avatar
Region: Oregon
I'm assuming you are talking 500hp at the crank and not the rear wheels...if you are talking RWHP then I'd say the 7.5 will be living a short life.
There are guys out there making close to 1000hp and running 8.8 rear ends.
I had a Whipple Charger on my 97 Cobra and tried 12/13psi on the mostly stock DOHC 4.6l and started breaking ring lands although the 8.8 was never an issue...my Maverick had an 9" and the single carb 408 was 650 at the flywheel and 544 lbft or torque...when you hit the transbrake button at 5000rpm you wanted to make sure the rearend was in one piece.
I had a friend with a 500hp motor and 7.5 rearend...he put slicks on the car and turn mid to high 11's...the rearend lasted 3 or 4 weekends before it expired.
I'd also recommend a "C Clip Eliminator" just to be safe even if you do have rear disc brakes.
Also hope the chassis is set up to handle the 200 extra HP.
Old 02-04-2017, 11:00 PM   #12
Region: Nevada
Good info. I am not dragging my car just daily driver.
Old 02-12-2017, 08:46 PM   #13
tman1020's Avatar
Just picked up a used 8.8 with a 3:55 this weekend to to swap out my 7.5. I think I'm going to have to get the conversion flang to make it work.
I'm hoping it will improve my lanch. Ever since the x charger my launches suck. Lots of one wheel Peel.
tman1020 is offline   Reply With Quote
Old 02-12-2017, 10:07 PM   #14
Region: Nevada
Thats sounds good. I just found out that my 3.73 8.8 will not work because the 7.5 housing is to small so i was told i just need to buy a gt rear. So i am going to wait on that one but i can still go 3.73 7.5 so i might do that. Right now i found a complete turbo kit for my car so i am saving a little money to buy it in about 4 to 5 months from now i should be able to buy it.
Old 02-12-2017, 10:44 PM   #15
How much for that turbo kit and from where?
Michaelg44 is offline   Reply With Quote
Old 02-12-2017, 10:48 PM   #16
Region: Nevada
3200 complete turbo kit from mrt performance they have a web site but they do not have this kit listed you have to contact them for it. They also have a twin turbo set up as well.
Old 02-13-2017, 06:18 AM   #17
tman1020's Avatar
That would definitely be cool. A turbo would really get that thing moving. Is your car a stick or auto?
Old 02-13-2017, 08:15 AM   #18
Region: Nevada
Mine is an auto. The thought of a rpm staller crossed my mine but that would a lot later to do
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
8.8 Rear end needed 67mustang97 Mustang Parts for Sale and Wanted 0 01-09-2010 10:02 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
well im really really bored right now Zim The Bar 19 01-06-2004 08:30 PM
im really really bored. Zim The Bar 0 11-17-2003 03:59 AM
06:19 AM
