Cast Iron Thermostat Housing - Mustang Evolution
Old 10-13-2016, 12:26 PM   #1
The plastic thermostat housing officially busted and spewed coolant everywhere on my 07. So I ordered the cast iron housing from Amazon and I plan on installing tomorrow. I will share some pictures with you all and let you know how everything goes..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
CJZona is offline   Reply With Quote
Old 10-13-2016, 12:53 PM   #2
MustangmanV6's Avatar
Yeah I was looking in replacing mine when I had the time, but instead it decided to bust a leak on the highway and so needed to get it replaced with a plastic one again. Def will be upgrading it before it does it again.
MustangmanV6 is offline   Reply With Quote
Old 10-13-2016, 03:35 PM   #3
Mirage's Avatar
Not sure if you meant to say "cast iron" housing or not, but it's actually cast aluminum. Just don't want anybody thinking they're getting something they're not expecting. But I can personally vouch for this part. I've been using it for a bout 3 years now, and not a single problem.
Mirage is offline   Reply With Quote
Old 10-13-2016, 04:52 PM   #4
No you are right it is ALUMINUM***
Old 10-14-2016, 12:40 PM   #5
Its in! Im a novice mechanic not a pro but, it took approx. 4hrs to install on my own with little difficulty. Plus this video also helped..
https://youtu.be/lUKL7liDKLI
Only thing I would have done differently is preclamped the bottom hose before putting everything on because it was a tight squeeze!
As you can see the mess created by the busted thermostat housing was pretty bad.. &So far no leaks from the new thermostat housing.
ID:	205677   Click image for larger version
Old 10-14-2016, 08:27 PM   #6
While I was at it I also put in these blue LED lights
Thermostat Housing/water neck? NeedSomeMods 1979-1995 Mustang GT 19 04-22-2012 09:39 PM
Thermostat housing leaking. Please Help! dmax8709 1996-2004 Mustang GT 0 02-06-2012 06:17 PM
Thermostat Housing Tj88mustang 1979-1995 Mustang GT 8 11-27-2011 08:38 PM
GT40 cast iron heads....... Vinnietbird 1979-1995 Mustang GT 8 10-21-2005 01:45 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
07:29 PM
